94 eg couple swap (need help)
Old Jun 16, 2008 | 03:42 PM
thcap1's Avatar
Default 94 eg couple swap (need help)
my boy has a 91 d15 sohc non vtec block. the eg couple has a blown d16y sohc vtec (big *** hole in the block by #3 cly ) can we use the d15 block (non vtec) with the d16 head(vtec) any advice would be greatly appreciate
Old Jun 16, 2008 | 04:59 PM
jimmy o.'s Avatar
the d16Y8 is obd2 the D15b7 is obd1 and d15b2 is obd0
what kind of vehicle are we talking about here??
Old Jun 16, 2008 | 06:28 PM
spooled-r's Avatar
Default Re: (jimmy o.)
yes you can but would not recommend its always a hassle and does not usualy make any extra power but if thats all you have and need to make do it will work.
Old Jun 16, 2008 | 06:30 PM
ABlais's Avatar
Default Re: 94 eg couple swap (thcap1)
with the amount of money you will spend on using the d15 block your better off just getiing a new d16. It takes a bit of work to use the d16 head on the d15.. And d16's dont go for that much money.
Old Jun 24, 2008 | 11:01 PM
thcap1's Avatar
Default Re: 94 eg couple swap (ABlais)
yea we just went and got a d16y8 so thnaks for all the posts
trooper0641
Oct 23, 2008 04:12 PM
rico892002
Jun 11, 2007 10:12 AM
og_hatch_90
Dec 20, 2006 03:25 PM
