oil light flickering???
Old Jul 17, 2002 | 02:39 PM
jdmhatch94's Avatar
Default oil light flickering???
i jsut chaged the oil .. has about 4.5 quarts in it(b18c1) and i take it fora rive and come back let it idle and the light (oil) starts to flicker???
Old Jul 17, 2002 | 06:56 PM
tinkerbell's Avatar
Default Re: oil light flickering??? (jdmhatch94)
only at idle?
how many miles on the engine? did you rebuild it?
check that the oil filter was put back on properly (you did change that too didn't you?)
maybe you have an oil pressure problem somewhere?
(for those that dont know - the oil light does not mean low oil - it means low oil pressure!!!)
t..
Old Jul 17, 2002 | 07:15 PM
MattG's Avatar
New User
Check everything noted. If you are lucky you have a bad sensor and not an engine problem. I would get it checked out ASAP to ensure your not damaging your engine.
Let the car sit and re-check the oil.
Old Jul 17, 2002 | 07:20 PM
jdmhatch94's Avatar
Default oil light
yeah i bought it from a friend... rebulit it says it has 2k on it after rebuild.. i changed oil and filter...
Old Jul 17, 2002 | 07:52 PM
tinkerbell's Avatar
Default Re: oil light (jdmhatch94)
rebuilt as in taken apart and put back together again?
sounds like it could have loose bearing clearances...
or a worn oil pump,
someone may suggest that you can shim hte oil pump to increase the pressure, but im not sure how to do this
check first with your friend about the state of the crankshaft and bearings when he/she pulled it apart...
and ask him/her what was replaced or machined in the rebuild.
t..
Old Jul 17, 2002 | 09:13 PM
Kamin's Avatar
Default Re: oil light (tinkerbell)
isnt 4.5 quarts a little high if you didnt change the filter? (never done a gsr change)
but an oil light that flickers means its fluctuating near low/no oil pressure. i had a similar problem with mine.
Old Jul 18, 2002 | 03:40 AM
kinesistech's Avatar
Shimming the oil pump is done by removing the plug on the bottom, a spring will come out. If you put a shim or spacer or washer or whatever, it will change spring tension on the oil relief valve.
Pressure does not equal volume. If there are loose bearing tolerances pressure will only take care of the light not the problem. If you actually dig far enough to shim it, just put new bearings while you're there. Usually if you see the light assume yo **** is dead. That thing goes on when there like 5 psi.
lonewsome
Jan 1, 2009 01:42 PM
95_red_dc
Apr 2, 2008 06:17 PM
xlee08
10
Apr 1, 2008 02:00 PM
sublimenerd
16
Sep 25, 2006 02:33 AM
ludeman92
Nov 10, 2005 11:02 AM
