2000 Accord SE "phony" check engine light
Old Jun 16, 2008 | 01:30 PM
bmarchio's Avatar
Default 2000 Accord SE "phony" check engine light
I have a 2000 Accord SE with 123k miles. Had O2 sensor replaced 10 months ago, check engine light came on again, claiming same O2 sensor is failed. I understand a service bulletin came out claiming that the ECM (ECU?) had to be replaced as it's erroneously reporting a bad O2 sensor when it's actually okay.
Do I really need to do this if I can live with the check engine light on? Will the O2 sensor (and therefore my gas mileage, etc.) still function properly?
The repair is big $$$, so I'd like to avoid, so long as I'm not harming my car, or wasting fuel. Please advise - thanks!
Old Jun 16, 2008 | 05:48 PM
Mr Yamada's Avatar
Default Re: 2000 Accord SE "phony" check engine light (bmarchio)
When the CEL is on, the control unit runs in a 'default' mode ignoring certain sensors and using fixed parameters,
Yes fuel economy will suffer.
Service Bulletin 00-046 pertains to 98-02 ULEV and 00-02 SULEV <U>only.</U>
Was the replacement O2 sensor Denso brand?
Old Jun 16, 2008 | 08:26 PM
stereo69's Avatar
what was the code as I hope it was a heater failure or bad or low signal and not because of the P0420 code..
Old Jun 17, 2008 | 06:29 AM
H23 Power's Avatar
Default Re: (stereo69)
if the repair is replacing the ecu. get a used one. You can get them for around $50. You will have to get the dealer to reprogram the imobilizer.
265Kandcounting
Dec 19, 2017 12:57 PM
Kaya2763
Oct 28, 2010 06:39 AM
bliss22
Jan 16, 2008 01:03 PM
civicsaremean
Jun 24, 2007 08:27 AM
the_0ne
Jul 16, 2006 08:01 PM
