Trouble with my VSS (CEL 17) YAY!!!!! Advice please...
Old Jun 16, 2008 | 12:50 PM
daluv's Avatar
Default Trouble with my VSS (CEL 17) YAY!!!!! Advice please...
So, a few weeks ago, my speedo stopped working and I started throwing CEL #17. Soooooo, I get a new VSS, put her in, unplug my ECU fuse, let it sit for a few minutes, plug it back in and take her for a ride. Speedo works fine, however I am still throwing the CEL for my VSS!?!? Everything seems to be working fine, my speedo, my Tach, etc. Did I miss something? Help would be appreciated! Thanks in advance!
Old Jun 16, 2008 | 12:59 PM
SeVeNisOnE's Avatar
Default Re: Trouble with my VSS (CEL 17) YAY!!!!! Advice please... (daluv)
Have you tried disconnecting the battery then reconnect and see if the CEL resets?
Old Jun 16, 2008 | 01:27 PM
pdiggitydogg's Avatar
You may want to check the wiring on the vss itself.
I had an issue like that before, where the speedo worked but the ecu wasnt getting a signal.
Check for continuity between the ecu and the vss. Go from there.
Old Jun 17, 2008 | 12:23 PM
daluv's Avatar
Default Re: Trouble with my VSS (SeVeNisOnE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeVeNisOnE &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried disconnecting the battery then reconnect and see if the CEL resets?</TD></TR></TABLE>
Yeah I tried that one already, didnt work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">You may want to check the wiring on the vss itself.
Check for continuity between the ecu and the vss. Go from there.</TD></TR></TABLE>
Ill give this a try and see where I get. Thanks guys!
Pure Sol
Feb 11, 2011 07:26 AM
jordan71
Apr 8, 2008 05:42 PM
srb7f
13
Oct 20, 2005 10:41 PM
genetsang
Jun 24, 2003 12:24 PM
BoostedGSRBubble
May 10, 2002 08:40 AM
