how to relocate the battery to trunk?
Old Jun 16, 2008 | 11:55 AM
danno33's Avatar
Default how to relocate the battery to trunk?
i want to put my battery in the trunk to make more room, i know how to do it but is there anything i need to know? is it not good for efficiency? where should i run the power and ground cables?
thnks guys
Old Jun 16, 2008 | 12:05 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: how to relocate the battery to trunk? (danno33)
unless someone pulled the link down it was in the FAQS
Old Jun 16, 2008 | 12:09 PM
Red_ED8's Avatar
Summit and PasswordJDM sells relocation kits but you can just piece together a kit for less then half of what they sell it for (wish I did ). When I did mine I just ran the power wire through the fire wall (and use a grommet) on the passenger side and run it along with the fuel lines straight to the back.
Old Jun 16, 2008 | 12:18 PM
Red_ED8's Avatar
Default Re: how to relocate the battery to trunk? (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">unless someone pulled the link down it was in the FAQS</TD></TR></TABLE>
X2
Old Jun 16, 2008 | 06:36 PM
danno33's Avatar
Default Re: how to relocate the battery to trunk? (Red_ED8)
where would i run the ground??? somewhere in the trunk i guess?
Old Jun 16, 2008 | 07:20 PM
yamaha6611's Avatar
yes, you could find a spot... but IMO i wouldnt. thats 40 or so pounds off of the front wheels, and more to the back.. which in turn can have an effect on your traction.
Old Jun 17, 2008 | 09:37 AM
danno33's Avatar
Default Re: how to relocate the battery to trunk? (yamaha6611)
i was thinking about that but its not too big of a deal as long as ya got good tires...besides i wanna make room for this massive carbon fiber intake i found on password jdm...its so big i need the battery out to make it fit, but i think its will all be worth it...
Old Jun 17, 2008 | 09:47 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danno33 &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking about that but its not too big of a deal as long as ya got good tires...besides i wanna make room for this massive carbon fiber intake i found on password jdm...its so big i need the battery out to make it fit, but i think its will all be worth it...</TD></TR></TABLE> Those intakes are junk honestly, and FWD always suffers from traction problems good tires or not, you can also get the PWJDM battery thing they sell.
Old Jun 17, 2008 | 12:18 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danno33 &raquo;</TD></TR><TR><TD CLASS="quote">i want to put my battery in the trunk to make more room, i know how to do it but is there anything i need to know? is it not good for efficiency? where should i run the power and ground cables?
thnks guys</TD></TR></TABLE>
Make sure you get a sealed battery. The Odyssey PC680's are the most popular.
And here are some good reads:
http://crx.honda-perf.org/arti....html
http://www.homemadeturbo.com/t....html
Old Jun 20, 2008 | 10:36 AM
mrvrsick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yamaha6611 &raquo;</TD></TR><TR><TD CLASS="quote">yes, you could find a spot... but IMO i wouldnt. thats 40 or so pounds off of the front wheels, and more to the back.. which in turn can have an effect on your traction.</TD></TR></TABLE>
You know, i thought that they were usually front heavy, and dont we want to do exactly that? take weight off the front? i would assume that being closer to 50/50 would be better....
right?
Old Jun 22, 2008 | 02:06 PM
Wafler's Avatar
Agreed, balance &gt; traction
Old Jun 25, 2008 | 08:49 PM
yamaha6611's Avatar
Default Re: (Wafler)
what? noo theres no way.. what you need is all the weight in the front, cause when you launch its going to naturally throw the weight to the back, and loose traction.. ever see the civic drag cars that have a wheelie bar??? reduce that throw back by:
well say there is no way to get less than 2700 pounds.. the motor is a good chunk of the weight.. use the rest of the weight on the front and stiff springs in the rear will stop the roll.. thats why rwd is so nice for traction, all the weight is transmissed to the back wheels... best traction.
Old Jun 25, 2008 | 09:12 PM
ketchup's Avatar
Default Re: how to relocate the battery to trunk? (mrvrsick)
Depends on what you want from the car. 50/50 is ideal weight distribution for great handling. If you're gonna drag the car then I guess you want to keep the weight up front? I'm not sure.
Be sure to secure that battery real good.
Old Jun 25, 2008 | 09:29 PM
cashflip's Avatar
I'll trade you my battery in my trunk for yours in it's stock location lol. Seriously though, I can't put **** in my trunk without getting battery acid on it.
Old Jun 25, 2008 | 09:48 PM
ketchup's Avatar
Default Re: (cashflip)
drycell battery http://crx.honda-perf.org/arti....html
Janos Lin's Avatar
Yeah like what they're saying. If ur gonna drag, leave it up front, but if its anything else, ur better off moving it out of the front. Someplace low and on the passenger side is good. Such as in the passenger's seat. Who cares about the passenger? Or right behind the passenger seat. But please, dont put it over the rear axle.
The only time you have a dramatic unloading of the front wheels is under hard acceleration from a stop. Otherwise the weight transfer is significantly less.
Moving the battery to the center/passenger side moves weight closer to the center of gravity, and possibly lower. And also decreases the moment of inertia. Plus it'll help offset the side to side imbalance of the dork in the driver's seat
Find a nice, solid piece of metal near the battery, and use that as your ground. Bare metal with dielectric grease is preferable. Make sure your box is vented to the outside of the car.
Janos
Old Jun 26, 2008 | 03:58 AM
harmonator84's Avatar
Default Re: (Janos Lin)
Also make sure you put a inline fuse on your power wire. You want it 6-12 inchs from the battery. Its really easy to do. I done it to my car....you can check it out in my build thread.
ryukiori
May 19, 2008 02:03 PM
RACEPAK
Mar 26, 2006 05:17 PM
Power Rev Racing
60
Dec 14, 2005 09:09 AM
Jamez
Welding / Fabrication
Jun 12, 2005 09:45 PM
ben_eg6
Oct 5, 2004 04:04 PM
