~*Post up your A/C Block off's*~
I know alot of us have removed the A/C system, its rec. that you block off the open spot to prevent water from splashing onto your blangin turbo/manifold/header. Post up what you got.
:fingers crossed:
:fingers crossed:
So why did you post in here then
I didnt replace mine with anything water wasnt an issue with mine and I dont think much water will get in there with teh intercooler up there too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ErrDizzle »</TD></TR><TR><TD CLASS="quote">stock 96-00 civics with no a/c come with a plastic panel to cover the opening. I would just get an integra radiator to cover the opening.</TD></TR></TABLE>
Shoot, I shoulda consulted with NOFX, If this is true im goign to do a backflip
Sure an integra rad would be nice, but I want things to fit like OEM when it comes to my radiator I dont want to fab up some brackets. ANyone have a part number on the block off plate? I cant find anything on majestichonda.com
Youll find alot of what youre looking for in here: https://honda-tech.com/zerothread?id=1693934
Thats what I did with my DD ej8-4. Now the block is all corroded, The DC header is warped from water being splashed on the head flange, and the car sputters durring more heavy rain.
What I did yesterday was retain the Condenser (but removed the actual fan [not the shroud -thats yoru mounting bracket]) And used an aluminum sheet on the front of the condenser. This will help direct more flow into the radiator, and looks clean and stock. Doesnt weigh much either.
CO_CReX
Apr 29, 2007 06:44 PM
