need help with EG
Old Jun 16, 2008 | 09:21 AM
lilcuban245's Avatar
New User
Default need help with EG
hi, im a lil new to the honda thing i just bought a 95 eg 5 speed and its completely stock, what i plan on doing to it swapping and getting a b20z but the thing is i cant find a jdm site that sells b20z for cheap i was wondering if u guys can help me with some links that would be great :D thanks
Old Jun 16, 2008 | 09:33 AM
95vxtealhatch's Avatar
Default Re: need help with EG (lilcuban245)
Do you have a plan for upgrading your honda? You'll be very disapointed if you swap a motor in first instead of getting your chasis and suspension ready. I suggest All new OEM bushings on your LCA's, and new Rear Trailing arm bushings & don't forget your front radous rod bushings. New struts & springs if you choose, Integra brakes (Rebuild them first) along with an upgraded 91 4 door ex master cylinder. Then your ready for a new motor, but i suggest new seats & tint before the motor. Its really nice to be able to throw people through the window when you hit your brakes. Plus stock brakes aren't enough to slow down anything bigger then the stock motor unless you have an SI Those already have the integra brakes.
Do yourself a favor, and avoid me saying i told you so, and just use my guidelines or create your own. To have the most enjoyable Honda experience A motor swap just isn't going to cut it.
Old Jun 16, 2008 | 09:36 AM
nicks-eg6's Avatar
Default Re: need help with EG (95vxtealhatch)
hmotorsonline.com
not the cheapest but one of the best places to buy a motor
Old Jun 16, 2008 | 09:44 AM
New User
Default Re: need help with EG (nicks-eg6)
i know that i just wanted to buy the motor so i can sit it on an engine stand while i save up for newer parts and also i want to put it all together before i swap but thanks for the help
Gascan52
Dec 4, 2011 11:01 AM
mikeunreal
19
Dec 17, 2005 12:32 AM
