ITR valve springs!
Hello,
Ive been using CTR/ITR cams for the last 7 months. Now im ready to upgrade to an upper level. Im ordering cam gears and OEM ITR valve springs and retainers.
I was wondering how high can I safely rev with the stock ITR valves springs and retainers?! And also with the stock B16A2 internal!
Also, is it a good idea to upgrade to a B18C5 ECU! Or should I simply raise the rev limite on my stock ECU!
Thank You!
Thank You!
ITR valvesprings are good to ~9100 rpm.
If I were you I'd get an OBDII-OBDI wiring harness and a chipped P28 ECU. I recommend a Mugen program.
[Modified by Reid, 12:46 PM 7/17/2002]
Thank You!
And what about the internals?
I do not plan on reving higher then 8500rpm anyway since the engine will probably not make power up there!
I only want to be able to use the CTR cams powerband and also drop higher on the powerband when im racing!
Thank You!
The car will make power up there now.
Get the stuff I mentioned above and get it on the dyno.
See where the power drops off with your own eyes.
I was already planning to do that. I went to the dyno twice so far.
137.8 whp with a drop in K&N
141.3 with an AEM CAI.
Hoping for 145whp with the cams... untune
thank you for the infos!
Maxime,
Maxime,
Downey
Oct 19, 2003 02:41 AM
