Short shifter decision
Hi,
I want to get a dual bend short shifter for my 97cx hatch... it has the stock D series motor in it... so I called my local shop and they told me that only a single bend is for the D series and dual is for B series motors... Is this true, or did I get the guy working his first shift???
Thanks A lot
Thanks A lot
I also have a skunk2 dual bend on my 92 dx hatch. They make them in both dual and single bends.
http://cgi.ebay.com/ebaymotors...l1116
Someone tell me the difference between 45074 and 45075 please, one has a pivot housing?
http://www.bmracing.com/index....at=15
I've been to a bunch of shops and not a single one has ever had a skunk2 dual bend for a D series motor.... either you are wrong, or these shops don't want to sell it to me... I hope you are right however... can someone post a website where I can order a skunk2 dual bend for a d16y7... SOHC motor... I would greatly appreciate the owning
Secondly, Rok Stok... I have a mint condition buddy club SS I ordered but it's for a b16... many websites advertise it fits 92-00 civics... but only if they have B series motors in them... that's why I think a lot of people think you can get a dual bend for a D series
when i had my 95 ej1 i went to the junk yard and got me an oem integra dual bend shifter, it fit but i had to use washers mounting it to the linkage and the best part i got it for $5, cant go wrong with that
I disagree with you my friend... Sure those specs are right... but that's not what's important... the motor specs are important... and 92+ civics with "B-series" motors can have dual bend... but if they don't they have to use single bends... I have a 97 ek with a D series and I wanted a dual bend for it... but im outta luck it seems
I'm using a B&M dual bend on my D16Y8, I don't understand why people would think it wouldn't work. The application list for my shifter lists '92-'00 civics & '94-'01 Integras, they should all be interchangeable.
ya but they are not... 94-01 integra's have B series shift linkages and I'm pretty sure that D series linkages are different... idk if you can modify it to fit tho... because I have a buddy club (dual bend) and it won't fit my D series
I personally would not get a short shifter
you are actually increasing the time between shift since you have to move your hand further down, I would perfer a taller shifter thats almost next to my steering wheel or close to it.
Plus most short shifter are light, now you have to push/pull harder to get it into gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jdmcivic »</TD></TR><TR><TD CLASS="quote">
Plus most short shifter are light, now you have to push/pull harder to get it into gear.</TD></TR></TABLE>
my fidanza short throw is the same hight as my Stock just the bottom after the fulcrum is longer
