Good Method to compress valve springs
Old Jun 15, 2008 | 03:34 PM
prolifikproficy's Avatar
Default Good Method to compress valve springs
So i bought a head the other night and today i was goin to compress the valve springs to take everything apart i found it really difficult to get my valve spring compressor ontop of some of the retainers beacause the shape of the head; is there a good method to do this?
Old Jun 15, 2008 | 03:45 PM
rebo0t's Avatar
easiest way to pop off the keepers is to tap the top of the retainer with a socket and mallet. only some spring compressor tools will work to reinstall, which one are you using?
Old Jun 15, 2008 | 05:08 PM
craftsman the c clamp type
Old Jun 15, 2008 | 05:15 PM
m00nr0ck Si's Avatar
Default Re: (prolifikproficy)
I used a craftsman conventional one but it was a pain in the A@@
Old Jun 15, 2008 | 05:17 PM
rebo0t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prolifikproficy &raquo;</TD></TR><TR><TD CLASS="quote">craftsman the c clamp type</TD></TR></TABLE>
yeah i've played with those before, its not really designed to use on our heads. you might need to invest in a snap-on/matco tool for the dohc heads. i have the snap-on one with a lever on it, there is also another tool that i've seen work pretty well offered by either company as well.
Old Jun 16, 2008 | 08:03 AM
ah i knew there was a better design. well i guess thats what i get for buying a cheap tool... a cheap tool. ill look in to that thanks
Old Jun 16, 2008 | 09:04 AM
bluedlude's Avatar
heres the tool im currently in love with.
https://honda-tech.com/zero...age=1
sik civic
16
Aug 17, 2005 05:58 PM
sleepin91teg
Jun 20, 2004 05:34 AM
ltho1998
Aug 3, 2003 05:45 PM
Wicked Sol
Dec 10, 2002 07:16 AM
SpeedracerS4
Dec 11, 2001 04:37 PM
