94 sol d16y8 antifreeze leak
Old Jun 15, 2008 | 03:28 PM
hondatuning1989's Avatar
Default 94 sol d16y8 antifreeze leak
alright so i recently built a y8 for my sol. i put it in broke it in and after about 2500 miles my temp guage spiked up to H....i stopped at a stream filled the empty radiator up with water and drove it to my friends shop...we couldnt find any leaks anywhere. i drove it home and bought a new waterpump for it. changed out the pump while i hooked up my a/c. if i let the car idle for about 15 min after driving it the temp guage will go to hot until i start driving it and when i beat on it i can smell that faint sweet smell of antifreeze. did a compression test and all cylinders read the same no loss of power so i dobt head gasket...i still have to stop every cpl hundred miles and fill up the rad. any ideas what could be doing this ....and like i said there is no leaks anywhere weve checked a million times...not noobs at all in the honda field and this is a stumper
Old Jun 15, 2008 | 03:36 PM
apexi_rsx's Avatar
check the drain plug might be leakin alil and possibly check the o-rings that are on the tube that runs from the thermostat to the water pump. could be possibly a hole in the radiator?
Old Jun 15, 2008 | 03:42 PM
Default Re: (apexi_rsx)
there isnt anything leaking anywhere in the car tho i can beat the Pis outa it for like 30 min straight park it in my garage for a cpl hours and there is nothing its a brand new rad. and the thermo was replaced a cpl mos ago
Old Jun 15, 2008 | 03:51 PM
Default Re: (hondatuning1989)
the only thing i could think would be that in either the ports in the head..intake or exhaust maybe a crack? so the antifreeze gets either sucked into the piston and shot out or its getting sprayed into the exhaust ports once i get hight revs and the waterpump creates more pressure in the motor
Old Jun 16, 2008 | 11:10 AM
apexi_rsx's Avatar
if the pistons getting water im sure u will melt a piston after beating on it enough water has hydrogen so when it gets hot enough its fried
Old Jun 16, 2008 | 12:01 PM
so how can i fig out my problem??? rip off the head and go from there?
Old Jun 16, 2008 | 02:37 PM
apexi_rsx's Avatar
possibly but if its got that hot hopefully the head hasnt worp or either has the block you can have it always checked out some where. in the mean time while its off u have plenty of places to check where its going. possibly just a nipple getting loose and leaking alil on the intake manifold. you never know. its about 50 bux for a gasket and its not hard to time. its up to you, your money and patience.
Old Jun 16, 2008 | 03:07 PM
malubawla's Avatar
go to autozone and rent out the coolant pressure tester and the import adapter......its about $120 which you will get back when you return the sfuff....you hook it up to the radiator where the cap goes, and pump 5-10 times....you will see antifreeze flow out from where the leak is.....
Old Jun 16, 2008 | 03:22 PM
superfast666's Avatar
Default Re: (malubawla)
i had a car do the same thing it turned out to be the radiator cap
Old Jun 17, 2008 | 01:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone and rent out the coolant pressure tester and the import adapter......its about $120 which you will get back when you return the sfuff....you hook it up to the radiator where the cap goes, and pump 5-10 times....you will see antifreeze flow out from where the leak is.....</TD></TR></TABLE>
yea i have a tester and it didnt leak out or loose pressure anywhere......so i suspected the rad cap but its a brand new rad and cap ....i replaced it...same prob still
Old Jun 17, 2008 | 05:20 PM
is the thermostat installed correctly
Old Jun 23, 2008 | 10:44 AM
PI2valve's Avatar
Default Re: 94 sol d16y8 antifreeze leak (hondatuning1989)
Its a stuck thermostat
david1953
Oct 22, 2017 03:13 AM
kimbothegiant
10
Dec 14, 2014 05:54 AM
powersk8er92
Jun 30, 2012 08:36 AM
thatcivic96
Jan 26, 2011 09:44 AM
BionicElite
18
May 4, 2008 09:29 AM
