just got my Tein's
Old Jun 15, 2008 | 02:00 PM
JLSpeed's Avatar
Default just got my Tein's
just got in my Tein basic dampers for my EG hatch, and come to notice, modacar.com sent me the model for the EK - i don't think this is a problem though, is it? Aren't the suspensions on EG and EK are almost identical?
Modified by JLSpeed at 4:03 PM 6/15/2008
Old Jun 15, 2008 | 02:05 PM
4doorek96's Avatar
Default Re: just got my Tein's (JLSpeed)
yes
Old Jun 15, 2008 | 03:04 PM
JLSpeed's Avatar
Default Re: just got my Tein's (4doorek96)
yes they're identical, or yes I'll have a problem installing them
Old Jun 15, 2008 | 03:22 PM
melsers's Avatar
the rear lca is thinner on ek's
Old Jun 15, 2008 | 03:28 PM
4doorek96's Avatar
they will be just
fine you won't know or feel the difference
Old Jun 15, 2008 | 03:32 PM
HondamanXxX's Avatar
GO GIANTS!
Hmmmmm. Doesn't sound right to me.
Old Jun 15, 2008 | 03:47 PM
JLSpeed's Avatar
Default Re: just got my Tein's (melsers)
i just went out and did a preliminary look - yeah the bottom fork on the rears seems to be a little wider than the Tociko blue's that are on the car now. But, there was a fair sized gap between the fork and the actual control arm. I thinking they might just work.
Old Jun 15, 2008 | 03:49 PM
sde780's Avatar
I know you're supposed to use washers when installing the rears from EGs to an EK
Old Jun 15, 2008 | 03:59 PM
4doorek96's Avatar
Default Re: just got my Tein's (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Hmmmmm. Doesn't sound right to me.</TD></TR></TABLE>
i have fifth gen four doors on my ek (my friend had them under his name at autozone) and they were wider in the back but when I tightened the strut bolt they pulled together
Old Jun 15, 2008 | 04:00 PM
GO GIANTS!
I always thought that EG and DC suspensions were interchangeable.
Old Jun 15, 2008 | 04:07 PM
4doorek96's Avatar
not 100% sure about the front but the back works fine for me
Old Jun 15, 2008 | 04:10 PM
count me out's Avatar
* B A N N E D *
who said anything about a dc? ek is what they sent him.
use some spacers in the rear, the fronts will bolt up fine.
Old Jun 15, 2008 | 09:40 PM
JLSpeed's Avatar
Default Re: just got my Tein's (count me out)
wait hold on, I thought it was that EK rear control arms were thinner (according to previous post) thereby making it difficult to wedge a rear suspension designed for an EK over an allegedly thicker EG rear control arm .......... making this install relatively impossible. is this the case?
Old Jun 15, 2008 | 09:41 PM
JLSpeed's Avatar
also, yeah, I too thought (although irrelevant) that EG/EK suspensions were interchangeable with DC
Old Jun 15, 2008 | 09:45 PM
KonGo97's Avatar
i think it should be ok, cause when i bought my ek, previous owner put on eg6 suspension on it.....i have no problems........
Old Jun 15, 2008 | 10:25 PM
Romo Pyro's Avatar
Default Re: (sde780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sde780 &raquo;</TD></TR><TR><TD CLASS="quote">I know you're supposed to use washers when installing the rears from EGs to an EK</TD></TR></TABLE>
So THATS what happened. Some dude sold me Tokico blue and eibach springs for 200 and the rear shock forks were hella wide. I had to use spacers... But it worked out just fine. So I geuss what im saying is-&gt; you'll be fine.
Oh and BTW quick poll on spring preferance
Ebay adjustables or Eibach Performance? Im looking for a stiffer ride.
Old Jun 15, 2008 | 11:34 PM
fresheg760's Avatar
Default Re: (Romo Pyro)
they will be fine
Old Jun 16, 2008 | 02:31 AM
mormonboy's Avatar
Default Re: (fresheg760)
i dont think they'll fit. EK lcas/ lower shock mounts are more narrow.
EG/DC lca's r wider.
Old Jun 16, 2008 | 05:56 AM
JLSpeed's Avatar
anyone know for sure?
Old Jun 16, 2008 | 06:10 AM
GO GIANTS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">who said anything about a dc? ek is what they sent him.
use some spacers in the rear, the fronts will bolt up fine.</TD></TR></TABLE>
No one. The OP is taking about interchangeable suspensions. I wanted to clarify that EG and DC suspenssion are interchangeable.
Old Jun 16, 2008 | 06:30 AM
* B A N N E D *
why? post ***** much?
Old Jun 16, 2008 | 06:31 AM
GO GIANTS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">why? post ***** much?</TD></TR></TABLE>
....uh sure.
Old Jun 16, 2008 | 06:53 AM
hoo my gosh's Avatar
....uh sure. </TD></TR></TABLE>
uhh yeah. the subject is ek and eg, you're talking about eg and dc?
well to the original poster, ek rear lca's bushings are thinner than eg's. So, in order for you to put the ek suspension on, your rear lca bushings will need to be shaved/milled.
Old Jun 16, 2008 | 05:19 PM
* B A N N E D *
yeah dude, you dont post ***** at all, only 4000+ posts in less than 2 years.
get a life homo. and quit posting useless info.
Old Jun 16, 2008 | 05:46 PM
addiction2bass's Avatar
well any EG suspension will fit on a EK but a stock EK rear struts wont fit a EG.
only difference on the front struts is the brake line brackets which you can knock off and put onto your new struts if they dont come with them.
my old tok... blues where interchangable from 92-00 since they had the front brake brackets and wide rear forks and just spacers so they would fit a EK.
but my koni yellows at least in the rear are EK specific.
