Rough idle!!! HELP
Old Jun 15, 2008 | 01:31 PM
bigizsosexy's Avatar
Default Rough idle!!! HELP
I have a 2000 si (b16a2) in a 97 del sol.
My idles rough like a couple hundred rpms up and down.
I am throwing codes for IACV (14) which I changed no help, code still illuminated.
And code 41 for primary o2 sensor which there is no bung for it.
Main problem is car idling shitty and bad gas mileage which is causing me pain lol.
Any solutions for this?
Old Jun 15, 2008 | 04:54 PM
elektronsi's Avatar
Default Re: Rough idle!!! HELP (bigizsosexy)
primary o2 sensor is not an option for your car running properly, its a NECESSITY, get a bung welded on and hook that bitch up
Old Jun 15, 2008 | 08:32 PM
Default Re: Rough idle!!! HELP (elektronsi)
ok you got it bro. Thanks appreciate it!!
Old Jun 15, 2008 | 10:06 PM
bump
Old Jun 16, 2008 | 12:58 AM
God-Driven's Avatar
2K rmp? shounds like a vaccum leak, have you try to adjust the idle?
Old Jun 16, 2008 | 06:54 AM
Default Re: (God-Driven)
yeh not much of any help from that
Old Jun 16, 2008 | 10:12 AM
95vxtealhatch's Avatar
Wow i think you need to do some research on how a Fuel injected vehicle works.
You probly have an aftermarket header, which is the reason you don't have a spot for an o2 sensor. Get a bung weld it up get an o2 sensor plug it in the harness screw it in the bung. Now go get a Factory Honda Service Manual and read it from cover to cover. You'll find all the anwsers in there.
Pull the 7.5a fuse from under the hood to erase codes from memory.
Also Find someone who knows crome and have him tune your ECU on a wideband o2 sensor, then you won't even need that o2 sensor. I get 30-35 mpg with my d15b w/ex tranny in a vx hatch
Old Jun 16, 2008 | 02:08 PM
Default Re: (95vxtealhatch)
ok you got it. thanks
Old Jun 16, 2008 | 02:29 PM
I fixed the idle, FITV valve was [freak]ed.
But I GET SUCH BAD GAS MILEAGE, is it this o2 code you think?
ciRcuitJerk
10
May 13, 2003 05:18 PM
CrxSi707
May 1, 2003 11:41 AM
IloveNewt
Mar 24, 2003 12:53 PM
kHoA DoGG
26
Dec 28, 2002 09:14 AM
kHoA DoGG
Oct 31, 2002 11:44 AM
