96 civic hatch..did a automatic to manual...idle problem
Old Jun 15, 2008 | 11:56 AM
wacktical's Avatar
Default 96 civic hatch..did a automatic to manual...idle is fine but...
I used a 97 dx coupe engine and dash harness. I am puting a B20/vtec in it. I know that the map sensor plug is different so i traced the wires to the ecu and pluged in the harness that would fit. I started it up and it idles fine. but when i hit the gas the engine bogs real bad. I know the motor was running fine because i had it my 95 teg. Oh, i did have my old ecu so i just used my friends type-r ecu. any thoughts that could fix this would be greatly appreciated!
Modified by wacktical at 1:18 PM 6/15/2008
Old Jun 15, 2008 | 12:18 PM
apexi_rsx's Avatar
Default Re: 96 civic hatch..did a automatic to manual...idle is fine but... (wacktical)
you need a 5spd t/b and manifold so you can repin for a 2 wire IAC and run the 5spd FITV. im sure u have a 3 wire IACV under the t/b just check it out. and look for a 2 wire iacv swap
Old Jun 15, 2008 | 01:44 PM
wacktical's Avatar
the entire motor came off my manual integra...so none of that should matter
SELF MADE
12
Apr 22, 2014 04:22 PM
justinwazner
26
Nov 16, 2010 06:11 PM
7808
Feb 16, 2007 06:58 PM
LBDM EK97
Jun 26, 2005 08:46 AM
igo4bmx
May 28, 2004 03:26 AM
