Once again The rear brake on EJ1
Old Jun 15, 2008 | 08:10 AM
Mrtrunks's Avatar
Default Once again The rear brake on EJ1
First off, I'm sorry to bring it up once again, but I've looked and looked and looked...I still can't find a list of parts for a rear brake conversion for my EJ1. I know I need to get it off of an Integra GSR (94-01).
What parts do I need exactly? I know I need the trailing arm, lower/upper arm and the compensator arm...what else am I leaving out?
Also, do I need to change the proportion valve or do I leave it stock? Same with the master cylinder?
After I obtain the parts for the swap, what parts can I get after market and what application do I look under? (Integra or Civic?)
Thanks!
Old Jun 15, 2008 | 08:20 AM
eg_boi's Avatar
Default Re: Once again The rear brake on EJ1 (Mrtrunks)
you need both the whole arms from the back including the ebrake line. you can keep the stock valve and cylinder. after you've done swapping you will need integra parts when u buy new stuff for the rear. the 92-95 civic suspensions will still work with the rear disk brake. it doesnt need to come off a gsr specifically, any other 94-01 integra will work.
Russ Carr
Honda CR-V & Element
Sep 5, 2018 11:58 AM
Agguhnitus
10
Feb 14, 2012 02:04 PM
feriotypeR
Aug 15, 2009 12:12 PM
94allmotor
18
Feb 6, 2009 01:09 PM
mike93eh
Feb 8, 2004 12:32 AM
