removal of side mirrors
Old Jun 15, 2008 | 05:48 AM
omarisramo's Avatar
Default removal of side mirrors
sup guys. well earlier today i see that my passenger side mirror has been hit and now it is dangling. how do i remove the wire? and how do i take apart the mirror?
Old Jun 15, 2008 | 11:05 AM
omarisramo's Avatar
bump
Old Jun 15, 2008 | 01:26 PM
shibbywhitedude's Avatar
Year? And with most every car you either pull the little triangle shaped piece of plastic from inside the car above the door panel off, or the whole door panel and remove the few screws that hold the mirror on. Then all you do is unclip the wire from the mirror. It's pretty simple.
Old Jun 15, 2008 | 01:30 PM
omarisramo's Avatar
Default Re: (shibbywhitedude)
sorry its a 95 accord lx
Old Jun 15, 2008 | 02:03 PM
I'm not too up on 95 accords since I own a 98 but I'm sure it can't be TOO different. Like I said you will probably need to remove the triangle shaped piece of plastic opposite the mirror inside the car or the whole door panel. Then remove the 3 or so nuts holding the base of the mirror onto the door. Then just unclip the wire coming from the mirror. Pretty easy, hardest part would be taking the door panel off lol Hope this helps
Old Jun 15, 2008 | 02:12 PM
omarisramo's Avatar
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shibbywhitedude &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too up on 95 accords since I own a 98 but I'm sure it can't be TOO different. Like I said you will probably need to remove the triangle shaped piece of plastic opposite the mirror inside the car or the whole door panel. Then remove the 3 or so nuts holding the base of the mirror onto the door. Then just unclip the wire coming from the mirror. Pretty easy, hardest part would be taking the door panel off lol Hope this helps</TD></TR></TABLE>
thanks man for the help, im gonna try this as soon as i get out of work
Old Jun 15, 2008 | 02:26 PM
No problem, if that doesn't help, I'll check in my friend's 94 Accord. It's gotta be close to the same if it isn't.
rf2017
Honda Fit
Jul 15, 2017 11:10 AM
GriFFIthS
Honda Civic (2001 - 2005)
Jul 29, 2008 08:19 AM
Libertariat
Nov 16, 2006 07:52 AM
slvrcivic97
Jan 21, 2004 08:50 PM
JDMy0
Aug 24, 2003 01:00 PM
