Boost?
Old Jun 14, 2008 | 08:40 PM
Christopherian1982's Avatar
Default Boost?
Is it safe to boost on a b16 with 90,00 miles on it for daily driven.
Old Jun 14, 2008 | 08:50 PM
z6hatchboy's Avatar
Default Re: Boost? (Christopherian1982)
run a comp test and a leak down first, it will tell you how healthy your motor is.
JdelMsolG's Avatar
more then likely yes, get a compression test, and maybe leakdown...... just get the guys installing the turbo to tell you if its a good idea or not haha.
Old Jun 14, 2008 | 09:10 PM
mnskateboarder's Avatar
Default Re: Boost? (JdelMsolG)
yeah it'll be fine, just dont push the motor too far and get a good tune and it will be all good.
Old Jun 14, 2008 | 09:20 PM
Default Re: Boost? (mnskateboarder)
Alrite ill do the comp. and leak down test in the morning. What should I be looking for?
Old Jun 14, 2008 | 10:32 PM
dividedas1's Avatar
nice even high numbers across the board
for the compression test that is.
Old Jun 14, 2008 | 10:57 PM
team1320_k26eg's Avatar
you should be fine.. just keep the boost at a safe level so your motor will be reliable.. don't go boost happy
guttamane2486
Mar 4, 2010 12:16 PM
EK FLY
Feb 8, 2006 06:03 PM
AccordCD5
Oct 14, 2005 01:10 PM
H.A.R.T B18C1EG6
Oct 4, 2004 10:18 AM
wuhungsixxx
Jun 12, 2002 03:26 AM
