o2 sensor spacer
Old Jun 14, 2008 | 07:06 PM
b18cisbetter's Avatar
Default o2 sensor spacer
has anyone used the O2 sensor spacer. does it work is it worth it
Old Jun 15, 2008 | 09:33 AM
welfarepc's Avatar
i wish i knew what you were talking about
u mean a heatsink to keep the sensor cooler?
Old Jun 15, 2008 | 11:39 AM
there is an o2 sensor after or in the cat/test pipe. in order to stop a check engine light from occuring due to a test pipe there is a spacer that can be purchased or made to space the sensor out of direct current of exhaust flow.
Old Jun 15, 2008 | 11:05 PM
welfarepc's Avatar
never heard of that... what you should do is wire up just one o2 sensor but run some resistors off to the other connector on the ecu so it thinks the cat is working properly.. diy ftw
BanEL
Nov 22, 2003 12:26 PM
SOHC_MShue
Jun 23, 2003 07:11 PM
JoshRambo
May 15, 2003 01:09 PM
smacked94gsr
Sep 19, 2002 06:35 AM
