problems after obd1 conversion
Old Jun 14, 2008 | 03:23 PM
carlthecrx's Avatar
Default problems after obd1 conversion
i just wrapped up my mini-me/obd1 conversion last night, and the car ran fine on the obd0 setup, but after i converted to obd1 i'm throwing a code 9 (cyp sensor) and the car runs like crap.. i know the cap needs to be replaced but i don't think it could be causing the car to run this bad.. its an a6 block, y8 head, z6 distributor and p28 ecu.. thanks in advance for any help
Old Jun 29, 2008 | 05:04 AM
Shikaido2004's Avatar
Default Re: problems after obd1 conversion (carlthecrx)
Im not to sure, but I know when you run OBD 0 two oxy sensors are used, and in OBD1 only one is used. I have an ITR header with one bong and I cant use it until i convert over to OBD 1 which will eliminate the other oxy sensor. Oxy sensors could make your car run like crap. Try looking into it see what others know
Old Jun 29, 2008 | 09:34 AM
BlueCrxNC's Avatar
Default Re: problems after obd1 conversion (Shikaido2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shikaido2004 &raquo;</TD></TR><TR><TD CLASS="quote">Im not to sure, but I know when you run OBD 0 two oxy sensors are used, and in OBD1 only one is used. I have an ITR header with one bong and I cant use it until i convert over to OBD 1 which will eliminate the other oxy sensor. Oxy sensors could make your car run like crap. Try looking into it see what others know</TD></TR></TABLE>
He's got a code 9... Oxygen Sensors won't cause this.
You need to double check that you put the wires in the correct places on the distributor connector and at the ECU. Did you use a jumper at the ECU? Brand? How about a jumper at the distributor? Is this a new/known good OBD-1 Distributor? What's wrong with the cap?, cracked?
Old Jul 4, 2008 | 08:38 AM
carlthecrx's Avatar
Default Re: problems after obd1 conversion (BlueCrxNC)
The cap was just old and needed to be replaced, it ran great when i put a new one on it. Its still throwing the code 9 though, i have triple checked my distributor jumper, and i ordered my harness off ebay, not sure of the brand.
The distributor was from a salvage yard, so i'm pretty sure it's the problem.
Old Jul 4, 2008 | 11:35 AM
BlueCrxNC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlthecrx &raquo;</TD></TR><TR><TD CLASS="quote">The distributor was from a salvage yard, so i'm pretty sure it's the problem.</TD></TR></TABLE>
Did you reset the ECU? If not, do so to see if the code still remains afterwards. If it does remain see below.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92-95 Civic Helm's Manual &raquo;</TD></TR><TR><TD CLASS="quote">
View of Distributor Connector from Terminal/Pin Side
-----------Tab-------------
- A --- B --- --- C --- D -
- E --- F --- --- G --- H -
Measure the resistrance between terminals of the indicated sensor *see table
SENSOR: CYL
CODE: 9
SENSOR TERMINAL: D, H
ECU TERMINAL: B11, B12
WIRE COLOR: ORN, WHT
Is there 350-700 ohms?
NO = Replace Distributor
Yes = Read further in manual...
I'd hate for you to replace the distributor unnecessarily if something happened to your wires.
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
yoffer
18
Dec 17, 2007 05:13 AM
MniMeHatch89
May 24, 2007 09:10 PM
4ghatch
Nov 24, 2004 08:00 AM
jamessh1
Jul 25, 2004 09:46 AM
