Kinda a n00b question about a spun bearing...
Old Jun 14, 2008 | 01:53 PM
SuckMyDOHC's Avatar
Default Kinda a n00b question about a spun bearing...
I know this is kinda a n00b question but I don't have much engine building experience. Is it possible to mess up a block by a spun bearing? Basic story is motor had rod knock, motor seized, and found out it had a spun bearing. I understand that the crank and some other things can be damaged but also easily replaced or fixed, but what about the block itself?
Old Jun 15, 2008 | 11:29 AM
inspyral's Avatar
Did you spin a rod bearing or a main bearing? A spun rod bearing can potentially damage the rod and and the rod journal on the crank. A spun main bearing could potentially damage the crank and the main journal in the block. Depending on the severity of the damage, the crank can be micropolished and the block mains can be line bored/honed.
ziggy3784
Apr 30, 2009 07:48 AM
D.Dappa
Jul 16, 2007 01:57 PM
HickamHatch
Dec 17, 2005 04:10 PM
hksbigboi4
Apr 16, 2004 07:48 AM
carblegal
Jul 2, 2003 07:32 PM
