D Series Cable Tranny Question
Old Jun 14, 2008 | 01:51 PM
Civic2bBuilt's Avatar
Default D Series Cable Tranny Question
Heres the situation...
Have a EF Hatch 4 speed.
Swapping a 5 speed Si tranny
I was told it is an si tranny but I dont know how to check. There is a code that says L3 I do believe.
The problem is that the 4 speed has 20 splines on the mainshaft. The one that is supposed to be an SI has 21.
So is this not an si or do I have to do something to make it work..
BTW- I tried the search and found nothing.
Thanks
Robby
Old Jun 15, 2008 | 07:02 AM
gibsanez's Avatar
Default Re: D Series Cable Tranny Question (Civic2bBuilt)
You need 5 speed hubs. You also need an SI clutch.
Old Jun 16, 2008 | 04:06 AM
mike93eh2's Avatar
Default Re: D Series Cable Tranny Question (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">You need 5 speed hubs. You also need an SI clutch.</TD></TR></TABLE>
no he doesnt. he cant just reuse the std axles.
you will need to get a clutch/flywheel to match the new trans with 21 splines.
i cant remember if this is right or not but you can look it up when ordering a clutch.
88's used a 200mm disc and 21 spline
89's used a 210mm disc and 21 spline
90-00 used a 212mm disc and 20 spline
Old Jun 16, 2008 | 04:09 AM
gibsanez's Avatar
Default Re: D Series Cable Tranny Question (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
My bad, I'm used to seeing these questions from B-swap threads
Old Jun 16, 2008 | 06:28 AM
89s1's Avatar
There is a place to look for the tranny code by the filler plug.
B000 is si trans, and A000 is dx. small tags, soif you cant find them let me know.
or search....
L3 doesn't help identify the type.
EFstyle
Jul 20, 2007 01:16 PM
fed
Apr 10, 2005 04:26 AM
civicdust
Feb 26, 2005 10:29 AM
C-REX 88
Sep 1, 2004 01:27 AM
CimorelliCRX
Feb 5, 2002 04:29 PM
