Help! AEM twin fire digital wiring??
Im runing a plug and play AEM EMS, AEM EPM, AEM coils and AEM twin fire Ignition Module.
Im got everthing wired up execpt for the 4 wires for the input channels for the ignition module. Im not sure wich wires from the EMS are the channels 1-4 that the igntion module asks for?
I see for the pin outs for the ems coil 1 2 3 5? do I wire to those but theres no 4?
Help will be greatly appreciated
Modified by Boosteddb8 at 4:04 PM 6/14/2008
If those are the available coil outputs for your particular box, than yes, you would wire the twin spark to those outputs. You just have to assign the coils the correct firing sequence and turn them on as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosteddb8 »</TD></TR><TR><TD CLASS="quote">Sorry Its and plug and play AEM EMS</TD></TR></TABLE>
what model number??
Boosted is correct though, if those are the only available outputs then just turn those on and set the order. Make sure your jumpers match the triggering edge you are using. The twin fire will accept rising or falling via a dipswitch.
what model number??
Yea I installed the system on my all motor crx, I have the 30-1040 EMS you need to go to AEM-power.com forums and look up the wiring diagram for your computer. We also had to call AEM and they told us to open the computer and change some jumpers. It works now and kicks ***!!!
BOMBCRU
Oct 28, 2008 11:21 AM
11psiTurboSI
Nov 10, 2004 05:42 PM
