97 Del Sol code 41...Again
Old Jun 14, 2008 | 12:12 PM
old man honda's Avatar
Default 97 Del Sol code 41...Again
I found the listing that said the code 41 was primary O2 sensor heater circuit. So I just went ahead and replaced the front (manifold) O2 sensor. Reset the ECU (removed the Back Up fuse). The car is still throwing a code 41! Any ideas why, or anyone know how to test the circuit itself?
Old Jun 14, 2008 | 04:05 PM
Bump
Really, anyone know why it would read the same code with a new O2 sensor?
Old Jun 14, 2008 | 06:03 PM
z6hatchboy's Avatar
Default Re: 97 Del Sol code 41...Again (old man honda)
Is your exhaust stock?
Old Jun 14, 2008 | 06:22 PM
nocturnaldragon's Avatar
What kind of sensor did you replace it with? Stock part or a universal you had to wire up yourself?
If its the universal check your wiring and the wire lengh.
Also check for a break in the wire going to the o2 sensor regardless could just be a bad connection or something simple like that.
Old Jun 15, 2008 | 04:47 AM
Replaced with a plug-in replacement, no wiring on my part. (Bosch OEM) It is a stock exhaust. Still can't get the darn code to clear! Tried reseating the connection and reset computer like 15 times now. This is frustrating!!!
Old Jun 15, 2008 | 07:48 AM
Went to Autozone and had the scan tool reset the ecu memory. Seems to have done the trick.
Thanks anyway.
Old Jun 15, 2008 | 03:26 PM
Default Re: (old man honda)
When you reset the ecu you have to step on the brake as well to "drain" what little charge may have been left in the ecu.
Or use the ecu tool
Old Jun 16, 2008 | 11:38 AM
All right. Now I'm completely frustrated. After the code was cleared by Autozone, i was good for one outing, then the blasted CEL again...code 41. What gives?
Why won't this clear?
Could the new O2 sensor be bad? (In the same way mind you..heater circuit)
Any help would be appreciated. I'm ready to throw this car in the dumpster...and it only has 63,000 miles on it. My teggy with 320,000 doesn't have troubles like this!!
Old Jun 24, 2008 | 01:23 PM
tx_ej8_49's Avatar
Check your ecu. I had the same code, replaced O2 with no change. Took the cover off the ecu to find burns spots in it. Bought new ECu...Bling! No more CEL, 525 miles later....
loki7714
13
Jun 3, 2011 04:01 PM
importnoodles
Mar 29, 2008 10:20 AM
95_red_dc
Sep 11, 2006 06:32 AM
iLOVEmyEMone
Dec 29, 2005 02:57 PM
dustinsterk
Dec 31, 2003 09:27 AM
