This car is giving me hell...
Old Jun 14, 2008 | 11:06 AM
ThePeanutHatchback's Avatar
Default This car is giving me hell...
Ok, I have searched for two hours now and haven't found anything yet. Here's my problem, i have a 94 civic vx hatch with a d15b7 in it... the car will start up and idle really high, at about 1,700. Then, over a period of about 20 or 30 seconds, the car will work its way down to an idle of about 1,100 or 1,200, then rev itself up to about 2,000 or 3,000, and then promptly die. It does the same thing every time. the CEL code is 10. I know that is the Intake Air Temp sensor, but would that cause my problem? I was also thinking IAC valve as well. I replaced the IAC valve, and I also rigged up a MAP sensor to the harness because the CEL was throwing a 3 code before as well. Well i fixed the MAP sensor problem and the 3 CEL code went away and I thought the problem was fixed but its not, now I'm getting the 10 code. So long story short, I have a new IAC valve, new MAP sensor, and am not throwing any CEL codes except for the 10. Just wondering if it could be anything else though, thanks!
Old Jun 14, 2008 | 11:17 AM
z6hatchboy's Avatar
Default Re: This car is giving me hell... (ThePeanutHatchback)
Start by fixing the iat sensor, then try cleaning your fitv maybe.
Old Jun 14, 2008 | 11:23 AM
Default Re: This car is giving me hell... (z6hatchboy)
ok, uhh could you tell me where exactly the fit valve is located, im having a hard time finding it maybe im just retarded...
Old Jun 14, 2008 | 11:27 AM
z6hatchboy's Avatar
https://honda-tech.com/zerothread?id=1564019
Old Jun 14, 2008 | 11:31 AM
Default Re: (z6hatchboy)
ok thanks man, I'll give that a try and see how it works
Old Jun 14, 2008 | 06:37 PM
Default Re: (ThePeanutHatchback)
ok, bad news, the FIT wasnt the problem, nor was the IAT... only other one I can think of is the TPS??? Any suggestions?
Old Jun 14, 2008 | 11:20 PM
obuhmyuh's Avatar
if there's not a prob with your IAT then why are you getting a code? Think about it. check the voltages and make sure its within spec, if not u prob have a bad sensor.
unplug your IAT and see if it does anything while the car is running, if nothing happens then something with your IAT is def messed up.
Old Jun 14, 2008 | 11:39 PM
serio_ENDLESS's Avatar
you sure you have the correct plug connected the iat is supposed to be red and the other green
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
Preferio
Jul 6, 2005 08:56 AM
Achenar
Oct 2, 2004 01:45 PM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
