Using ABS master cylinder w/o ABS...
Old Jun 14, 2008 | 08:19 AM
DC2MK's Avatar
Default Using ABS master cylinder w/o ABS...
Quick question, I removed the ABS on my Del Sol VTEC, and ordered all new lines and a new prop valve. The rear connection point on the master cylinder is a larger diameter threaded connection. I was going to cut the larger threaded connection off of the old line and put it on the new line and reflare.... Am I going to run into problems using the ABS master w/o ABS?
Old Jun 16, 2008 | 06:23 AM
DC2MK's Avatar
Default Re: Using ABS master cylinder w/o ABS... (DC2MK)
bump..............
Old Jun 16, 2008 | 06:36 AM
pdiggitydogg's Avatar
No problems.
Do exactly what you planned on doing. Be sure to double-flare the line.
Old Jun 16, 2008 | 06:53 AM
slvrcvc93's Avatar
Default Re: (pdiggitydogg)
Yea you will be fine Stopping should be much better because of the larger diameter Master Cylinder but double flaring the line is a must! You will feel an instant difference when you hit the brake. I actually have an integra one i am going to do on my hatch but i must bend an entire line for it and I need the proportioning valve for a non abs 90-93 integra. Which did you use ?
dustinbs144
Nov 10, 2010 05:27 PM
rdssk8rcs1
Mar 31, 2008 10:16 AM
Another Drew
Jul 4, 2005 06:35 PM
zCivic
May 4, 2004 05:49 PM
