Spark plug choices? New Pulstar or NGK iridium?
Old Jun 14, 2008 | 05:22 AM
Spanish_rice's Avatar
Default Spark plug choices? New Pulstar or NGK iridium?
I have gone over the dynos and just can chose, but i have narrowed it down to the two. Looking to see what others have to say about what would be better and why i guess.
http://www.sparkplugs.com/spar...fid=0
Old Jun 15, 2008 | 01:45 PM
Blown90hatcH's Avatar
Default Re: Spark plug choices? New Pulstar or NGK iridium? (Spanish_rice)
It helps if you post your setup. Normally NGK copper plugs work great and are used in many high hp applications.
Old Jun 16, 2008 | 05:19 PM
but they make less HP and you get worse fuel mileage with copper then with iridium or other higher end after market plugs.
Old Jun 16, 2008 | 06:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spanish_rice &raquo;</TD></TR><TR><TD CLASS="quote">but they make less HP and you get worse fuel mileage with copper then with iridium or other higher end after market plugs.</TD></TR></TABLE>
Haha. What ever you say man.
Old Jun 16, 2008 | 06:49 PM
i have dyno graphs here that prove they make less horse power, so prove me wrong
Old Jun 16, 2008 | 06:52 PM
the NGK iridium had one of the best overall numbers and definatly good bang for the buck considering that they last far longer then copper plugs. my only concern is that since the pulstar plugs work so differently that they may make even more HP if the timing had been adjusted.
Old Jun 17, 2008 | 03:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spanish_rice &raquo;</TD></TR><TR><TD CLASS="quote">i have dyno graphs here that prove they make less horse power, so prove me wrong</TD></TR></TABLE>
On what setup?
Old Jun 17, 2008 | 08:54 AM
Default Re: Spark plug choices? New Pulstar or NGK iridium? (Blown90hatcH)
your so useless, did you read anything on link at the top? those where dyno graphs using various plugs. in which all of the copper plugs where the lowest performers. why is someone who cant even read the only one here trying to give advice
Old Jun 17, 2008 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spanish_rice &raquo;</TD></TR><TR><TD CLASS="quote">your so useless, did you read anything on link at the top? those where dyno graphs using various plugs. in which all of the copper plugs where the lowest performers. why is someone who cant even read the only one here trying to give advice</TD></TR></TABLE>
Hahah. I am not trying to give advice. You are comparing a Neon...one car and the power/trq numbers that are +/-2 at most on one dyno that is not temperature or humidity controlled resulting in various K values that could account for the +/- 2hp. Seriously man. The only advice I give is from years of tuning cars and using various plugs. There is more to just peak power/trq numbers to selecting a spark plug.
Old Jun 17, 2008 | 03:41 PM
inspyral's Avatar
I have always used NGK copper plugs, and they have never given me any problems. I like to check my plugs often to see how my engine is running, and I probably change plugs every other oil change or so. I don't like to toss plugs in and forget about them because they're "supposed" to last xxxxx miles, nor do I like to pay exorbitant prices for spark plugs when NGK R coppers are ~$2/ea at any parts store.
Old Jun 17, 2008 | 06:11 PM
i have seen the dynos on honda motors as well, but those are the only ones i have available at the moment. but i have proof that copper is a waste. but all you want to do is argue. if you have a point to make then do it, show me some proof! all you do is flap your gums and blow hot air with nothing behind it.
Old Jun 17, 2008 | 06:17 PM
Thanks for the input inspyral, just looking for the best bang for the buck and extra power from something as simple and cheap as a plug and with the price of gas what it is coupled with the long life of other plugs makes the total cost far cheaper then copper. I do agree with you on checking the plugs as often as possible to check for fouling and such to make sure my engine is running right. I check every oil change but have had good luck in the past with iridium lasting and running smoother. I ended up getting the NGK iridium to run for now. Just running bolt ons for now but building another motor on the side. I do think i will get the pulstar though when i finish up with the build, but im probably going to be getting all the parts together for the better part of another year so i guess thats a bit of a ways off. Thanks for the input though
Old Jun 17, 2008 | 07:05 PM
ddd4114's Avatar
Don't get Pulstar plugs. They're about as useful as the Tornado.
JerkzEm1
14
May 3, 2005 10:05 AM
JdmBullet
Jan 18, 2005 04:49 PM
LOSERboy
13
Aug 13, 2004 10:56 AM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
RedLudeSH
Aug 21, 2003 07:35 PM
