Need a new turbo precision pt67 failed Which BW turbo would best suit my setup
Old Jun 14, 2008 | 01:21 AM
140sx's Avatar
Default Need a new turbo precision pt67 failed Which BW turbo would best suit my setup
Hi,
Basicly thats it.
I have a pt67 journal bearing turbo that **** on me in about 1300 miles, from my understanding precison has changed the way that they are makeing there turbos and many people are having issues with this. (that is here say)
Now im looking to get away from Garrett turbos for a little while and try out the new hottness of the BW turbo line.
Which turbo should i get that is the equalevent of a pt67, gt40 i wouldent even mind haveing it spool a bit faster then the pt67.
So any insite to which BW turbo i should lean tord would be nice.
Thanks
Zach
Old Jun 14, 2008 | 04:53 AM
m R g S r's Avatar
Default Re: Need a new turbo precision pt67 failed Which BW turbo would best suit my setup (140sx)
any warranty on the PT? 1300 miles it cant be too abused.....
Old Jun 14, 2008 | 05:13 AM
TheShodan's Avatar
Moderator
I'd really look at the S366 Borg-Warner. That will do quite the job that can replace the PT67 that you already have. Please give me a PM for specifications and other STUFF. One person who comes to mind with their last application was Tepid1. He has had fabulous results with the S366. I believe This was at about 12psi-13psi.
Here's a photo of one of them. Coating is an extra amenity. This is T4 flanged, but T3 v-band is also available. I like the exhaust wheels of the BW a bit more for the top end than the PT67. The PT67 uses a P-Trim 2.944" (74.77mm) as opposed to the larger BW wheel which is over 3.15" (80mm) for the exhaust wheel.
The A/R measurements are a bit different that what Garrett uses, but that is only because the volute of the turbine housing is wider than Garrett. Same math, different volume. For the T4 application, it uses a .83A/R 3.25" divided housing that uses a unique v-band clamp system to adapt. For the T3 v-band, it is the standard 3" v-band, but the larger 69 trim exhaust wheel (there are 2 options) is used best with the .70 A/R T3 V-band (don't let the number fool you, this holds the larger exhaust wheel, even moreso than the .85A/R option that is available.)
Old Jun 14, 2008 | 05:38 AM
TheShodan's Avatar
Moderator
Default Re: Need a new turbo precision pt67 failed Which BW turbo would best suit my setup (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">any warranty on the PT? 1300 miles it cant be too abused.....</TD></TR></TABLE>
Typically warranty issues don't come only from "abuse". There are many factors including the oil setup of the turbocharger on th car that can void many such warranties. Only after a diagnosis from the manufactuer/Master Distribtor will a warranty possibly be considered.
Old Jun 14, 2008 | 06:46 AM
xsi-t's Avatar
i deff agree the S366 is a great choice that is what im putting on my car. i sold my pt67rls and went with a S366. if you need priceing hit me up i can deffinatley take care of you we are a master dealer.
Old Jun 14, 2008 | 09:44 AM
rudebwoy's Avatar
PRECISION love to blame the customer for their turbo failure so the warranty is no good on their turbos anyways.
I have 2 PTE turbos failed on me, the first one started smoking and then the turbine wheel snapped off at 20 psi. the second one same thing, compressor wheel bolt broke off, they blame ithe first one on dirty oil because fed it from the sandwich plate, and second one, on oil starvation(my car puts out 70 psi oil pressure at WOT how is that oil starvation?). they refuse to repair it.
I change to a full garrett t67.
precision turbo
Modified by rudebwoy at 9:50 AM 6/15/2008
Modified by rudebwoy at 9:39 AM 6/23/2008
Old Jun 14, 2008 | 06:45 PM
140sx's Avatar
thanks shodan for the great info
Old Jun 14, 2008 | 07:35 PM
blinx9900's Avatar
Default Re: (140sx)
i'm glad to see people are finally realizing the truth about Precision turbonetics is just as bad imo
Old Jun 15, 2008 | 09:36 AM
mrbsponge's Avatar
i have a 366 on my car and love it.
made over 700 with it
ran a 10.02 with it
all on a T3 as well
Old Jun 16, 2008 | 07:10 AM
TheShodan's Avatar
Moderator
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i have a 366 on my car and love it.
ran a 10.02 with it
all on a T3 as well</TD></TR></TABLE>
Let me guess... T3 .70A/R?
marcj
Nov 1, 2010 11:34 AM
marcj
Feb 13, 2010 02:55 PM
Project-D
Oct 11, 2006 02:00 PM
Bangodango
May 25, 2006 11:13 AM
phillyd13
Oct 28, 2003 03:10 AM
