mineme swap, timing belt issue
Old Jun 13, 2008 | 09:26 PM
aznboi_2's Avatar
Default mineme swap, timing belt issue
a6 bottom end w/ y8 head w/ aem cam gear and y8 timing belt. The belt keeps moving back. i tighten up the tensioner bolt as what the manual says and it stills moves back. i aligned the crank pulley and the cam pully already too and when i put the timing gun on the timing is still off. i cant advance the dist any further either. should i drill the housing?
Old Jun 13, 2008 | 10:09 PM
D16SiHatch's Avatar
Default Re: mineme swap, timing belt issue (aznboi_2)
that belts too large. you need a d15b7 belt from a 92-95 civic dx or lx. trust me, i know. also you shouldn't have to advance your dizzy at all, put it back dead center and then get the correct belt. make sure your cam gear is set 4.5 degrees advanced also for the y8 head
thatseemslegit
42
Sep 17, 2015 09:07 PM
Cashieboi
45
Mar 14, 2012 04:48 AM
99civicman
Mar 6, 2009 04:41 PM
garageEF
Apr 30, 2007 04:47 PM
lazynok
Jul 30, 2004 10:11 PM
