JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
Old Jul 17, 2002 | 11:26 AM
darkknightwong's Avatar
Default JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
Hey everyone,
I about to get a JDM ITR 5 lug conversion for my 99 Civic SI.
I been told I will run into problems with my SI axles?
I was told that the JDM ITR 5 lug use a 36mm axle, while the USDM ITR and any other B series car uses a 32mm axle?
Can anyone shed some light on this??
I dont want to tear down my car and find out that I'm going to need more parts to get the 5 lug workin on my SI.
Has anyone used a JDM ITR 5 lug conversion before with stock USDM B Series axles?
And if they are different, does anyone know where I can get JDM axles? or should I just go buy the USDM Hubs from acura? I guess all I would have to change would be the front hubs and maybe the bearrings??
Thanks in Advance for the help.
DK
Old Jul 17, 2002 | 02:31 PM
Jackson's Avatar
Default Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (darkknightwong)
You will need the 36mm axles or change the hub to a 32mm.
Old Jul 17, 2002 | 02:46 PM
jeff652's Avatar
Use prelude out hubs on your Civic Si Axles and you'll be set!
Old Jul 17, 2002 | 03:15 PM
Default Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (jeff652)
I think.. Converting to Prelude Outer CV joint is what I'm going to do.
What Year Prelude Axles should I use?
Or if Someone knows where to get some JDM Axles..????
Thanks
DK
[Modified by darkknightwong, 12:21 AM 7/18/2002]
Old Jul 17, 2002 | 07:39 PM
pete96hb's Avatar
I have a question regarding the same thing i have a 96cx with 5 lug swap and im swaping in a b16a, what axles will i need to use. i have b16a ones already, plz any help will be great
Old Jul 17, 2002 | 08:26 PM
fowler!'s Avatar
Default Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (pete96hb)
You can use the b16a axles no sweat.
Old Jul 18, 2002 | 02:22 PM
pete96hb's Avatar
Default Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (fowler!)
thanks fowler
Quickridez_3
Oct 27, 2024 10:18 AM
cashkid2004
Oct 1, 2006 06:41 AM
KiNG $h!t
Sep 19, 2004 06:36 PM
Garrett
Jun 7, 2004 06:49 AM
Lenthrax
Sep 27, 2002 08:36 PM
