JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
Hey everyone,
I about to get a JDM ITR 5 lug conversion for my 99 Civic SI. I been told I will run into problems with my SI axles? I was told that the JDM ITR 5 lug use a 36mm axle, while the USDM ITR and any other B series car uses a 32mm axle? Can anyone shed some light on this?? I dont want to tear down my car and find out that I'm going to need more parts to get the 5 lug workin on my SI. Has anyone used a JDM ITR 5 lug conversion before with stock USDM B Series axles? And if they are different, does anyone know where I can get JDM axles? or should I just go buy the USDM Hubs from acura? I guess all I would have to change would be the front hubs and maybe the bearrings?? Thanks in Advance for the help. DK |
Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (darkknightwong)
You will need the 36mm axles or change the hub to a 32mm.
Use prelude out hubs on your Civic Si Axles and you'll be set!
Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (jeff652)
I think.. Converting to Prelude Outer CV joint is what I'm going to do.
What Year Prelude Axles should I use? Or if Someone knows where to get some JDM Axles..???? Thanks DK [Modified by darkknightwong, 12:21 AM 7/18/2002] |
I have a question regarding the same thing i have a 96cx with 5 lug swap and im swaping in a b16a, what axles will i need to use. i have b16a ones already, plz any help will be great
Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (pete96hb)
You can use the b16a axles no sweat.
Re: JDM ITR 5 Lug Conversion on 99 Civic SI - HELP (fowler!)
thanks fowler
