bolt in roll bar
Old Jun 13, 2008 | 08:13 PM
black0hatch's Avatar
Default bolt in roll bar
will a bolt in 4 point roll bar do anything for handleing in a crx? what about if i weld it in instead of using the bolts? and has anyone ever added on to make it a 6 point? also is it worth the wieght? this thing is a tank.
Old Jun 13, 2008 | 08:39 PM
~sp33~'s Avatar
EFB055
Default FV-QR
Are you tracking your rex? It's pointless and dangerous in a DD.
I don't think the handling benefits are worth the weight, but the safety benefits while at the track definitely are.
Old Jun 14, 2008 | 01:06 PM
Default Re: FV-QR (~sp33~)
yes track car in the works. hows it dangerous?
Old Jun 14, 2008 | 01:52 PM
grog's Avatar
Default Re: FV-QR (black0hatch)
the bars themselves become a hazard when used on a DD (even with padding) , you might smash your skull on them, (unless you happen to be wearing a helmet) you may not enjoy that.
Old Jun 14, 2008 | 04:33 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: FV-QR (grog)
4 point bolt ins are junk.
Really it's safer with out something like that.
What kind of racing will you be doing ? Get a hand book and see what's legal first off and we can help from there.
Old Jun 14, 2008 | 06:27 PM
Default Re: FV-QR (***$nyper)
well i was gona get it on a trade but it seemed really heavy for what it was so i figured id ask on here first. im not gona get it.
Old Jun 14, 2008 | 06:45 PM
Tyson's Avatar
Default Re: bolt in roll bar (black0hatch)
i really dont know where others are coming from.
6pt full rollcages are dangerous for the street and not recommended, imo.
a 4pt roll bar will be just great. even for the street.
i wouldnt consider it a handling device however. you can weld it in if you want. nothing stopping you.
Old Jun 14, 2008 | 10:49 PM
Default Re: bolt in roll bar (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt consider it a handling device however.</TD></TR></TABLE>
so its only purpose would be if i rolled over? i dont plan on doing that.
Old Jun 14, 2008 | 10:50 PM
Tyson's Avatar
then dont get it...
Old Jun 17, 2008 | 09:47 PM
eramthgin128's Avatar
I don't know what any of the others are talking about...
A 4-point roll bar will improve handling via less chassis flex... In a 4-point, there isn't really a chance of you hitting your head on it seeing as though the cross bar is seated behind and way above the seat. Unless your seat malfunctions, you can't hit your head on it. Welding it in would improve the reduction of chassis flex even more, but if you intend on getting a 6-point in the future, I wouldn't recommend it.
I am in the process of making my ef hatch a full track car. I am getting a 6-point roll cage, not only for safety but because it DOES improve handling.
Old Jun 18, 2008 | 07:20 AM
sgallagher's Avatar
Default Re: bolt in roll bar (eramthgin128)
It will also be beneficial if you want to use a harness which if used correctly will add safety and control since you are not moving around in your seat so much.
If your sole purpose is to eliminate chassis flex while driving on the street it will not be a dramatic improvement (depends what type of street you're on).
If you are going to build the vehicle into a "track" car then just save your money and build a 6pt.
Old Jun 18, 2008 | 12:41 PM
blaak-crx's Avatar
Default Re: bolt in roll bar (sgallagher)
My Autopower 4 point roll bar:
Head is not near any bars:
Old Jun 18, 2008 | 12:51 PM
Cln94EG1's Avatar
Default Re: bolt in roll bar (blaak-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaak-crx &raquo;</TD></TR><TR><TD CLASS="quote">My Autopower 4 point roll bar:
</TD></TR></TABLE>I want that EM Racing Bar Will that work in Hatch backs
Old Jun 18, 2008 | 12:54 PM
csingham's Avatar
crazy mad murdock
quick suggestion go to yotube and watch some videos. In a high impact your more than likely going to hit that bar on the recoil.
Even with that nice 5pt belt...which is at least in the right place
Old Jun 18, 2008 | 07:07 PM
efsublime's Avatar
what kind of steering wheel is that?
Old Jun 18, 2008 | 08:28 PM
Default Re: (efsublime)
it looks like there was a bunch of bars that got cut off that cage? so does your car handle good?
Old Jun 19, 2008 | 08:20 AM
blaak-crx's Avatar
Default Re: bolt in roll bar (Cln94EG1)
EM bars will work better on a hatch.
Old Jun 19, 2008 | 08:21 AM
blaak-crx's Avatar
Momo 295 mm steering wheel
Old Jun 19, 2008 | 08:26 AM
blaak-crx's Avatar
Default Re: (black0hatch)
It was a 6 point roll cage. I removed the sides bars and front bars. It's not the bars that will give better handling and the bars weigh alot! I still hear my car "flex". If you really want to renforce the chassis, it must be welded almost everwhere like a real race car.
Old Jun 19, 2008 | 09:25 AM
tommycrx's Avatar
Default Re: bolt in roll bar (csingham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csingham &raquo;</TD></TR><TR><TD CLASS="quote">quick suggestion go to yotube and watch some videos. In a high impact your more than likely going to hit that bar on the recoil. </TD></TR></TABLE>
Or, you could die in a rollover without one. I'm not trying to be a smartass, but I'm sure you could make up hypotheticals that would support either with or without. I'm not sure which would end up with a reduced fatality rate in the real world, but with the age of these cars, I wouldn't be surprised if the rollbar affords you slightly higher overall protection in a crash.
As to the original post, I did realize some reduced chassis flex when my 4-pt was bolted in as well. I'm glad I got it.
Old Mar 2, 2011 | 01:13 AM
Ed7touge's Avatar
Mine is bolted in also. Mine is also a DD & Weekend warrior.
Old Mar 2, 2011 | 08:59 AM
blue91EF's Avatar
pointless unless you have a real race car. window net, race seat with 5 point harness, helmet, door welded shut, lexan windows ect...
Old Mar 2, 2011 | 09:21 AM
4drEF's Avatar
Keyboard Humorist
Third post down he clearly said it's a track car.
Since he's on track and wearing a helmet anyway, skip the 4 point and get the 6 point and weld it in!
Old Mar 2, 2011 | 11:27 AM
csingham's Avatar
crazy mad murdock
I'm not going to make up a hypothetical situation, yet I will used statistics. Most people with roll cages I see are rolling around with them on daily drivers for looks (bolt on roll cages). Yes, you will be protected in a roll over as long as the bolts hold up under the structural stress.
Majority of accident non track are collisions are front and rear collisions, on top of that the top injuries sustained during any vehicle accident is: whiplash, head trauma, and head trauma...so putting a bar there for looks defeats the purpose without the proper equipment. Roll overs although to occur it wouldn't be to smart to have solid object where your water membrane head is rushing towards at the rate your car was travelling...watermellon cement and a little objects in motion tend to stay in motion.
A roll cage can do both harm and save your life, yet there is purpose and instruction to all tools so they are used in the proper manner and function.
doing this on a small laptop sorry for spelling erros
Old Mar 2, 2011 | 11:28 AM
CRX Toad's Avatar
I would have to say if you have never been on track, go to the track first and talk to some people then decided what to do from there. I see lots of wasted money on track from things people bought that do nothing for them but add weight.
Secondly as an instructor if I do not feel the car is safe or its safety equipment is proper I will not get in the car and pull the tech inspector over.
