just came from the track and 2nd gear is like its not there.......
Old Jun 13, 2008 | 06:16 PM
JUN.'s Avatar
Default just came from the track and 2nd gear is like its not there.......
I just came from the track and I did 3 passes... The best one was 15.7 missing 2nd gear..
Everytime I pulled from 1st to 2nd the 2nd gear was blank, like if it wasnt there then I pressed the clutch again and tried and it grabbed........ I think I was overeving or something, is this normal?
Also 3rd gear grinded whenever I changed to it from 2nd.... I think that my clutch cable needs to be adjusted.... Is this a possible solution?
Its a b16A obd0 with y1 tranny
Also, I wasnt letting off the gas while changing gears...
Modified by JUN. at 10:29 PM 6/13/2008
Old Jun 13, 2008 | 06:18 PM
JUN.'s Avatar
Default Re: just came from the track and 2nd gear is like its not there....... (JUN.)
r/t .294
60' 2.494
330 6.888
1/8 10.369
mph 70.94
1000 13.312
1/4 15.793
MPH 90.04
Old Jun 13, 2008 | 06:59 PM
saikouEF8's Avatar
loose clutch cable or the springs on your clutch disc are worn...
Old Jun 13, 2008 | 07:01 PM
JUN.'s Avatar
Default Re: just came from the track and 2nd gear is like its not there....... (saikouEF8)
my clutch cable it is loose because I cut it too much and I cant adjust it anymore...... But in normal driving 3rd doesnt grind when I change from 2nd,...
Old Jun 13, 2008 | 07:09 PM
saikouEF8's Avatar
ok...well... im not a big fan of full throttle shifting, but i still think the springs on your clutch disc are done...decidedly so because of the fact that its fine under normal driving. which gives the worn springs time to disengage the clutch disc.... why full throttle shift on a stock b16a...is it programed into ur ecu? i think ur hurting ur car.
Old Jun 13, 2008 | 07:50 PM
traxxasx's Avatar
Your powershifting.
My tranny does not grind, but if i power shift (not letting off gas) it does in 2 and 3.
evan221
Jan 27, 2014 06:14 PM
mrspeedy69
Jun 25, 2008 07:00 PM
trianglegreg
Nov 12, 2005 10:58 AM
srv3fender
Mar 24, 2005 07:16 AM
srv3fender
10
Mar 24, 2005 05:28 AM
