my setup, question?
Old Jun 13, 2008 | 03:41 PM
seldon's Avatar
Default my setup, question?
ok so i'm building an ls/vtec, would i still be able to run pump gas with this set up?
b18a1 block
ctr pistons
b18a1 rods (shot peened)
b16 head
brian crower stage 2 cams
brian crower dual spring and titanium retainers
brian crower 33mm intake valves
brian crower 28mm exhaust valve
4-1 header
skunk2 intake manifold, and skunk 2 throttle body, 68mm
ok well if any more setup info is needed i can give you it, the head is not planed, using OEM headgasket. also the valve size could change if u think i can go bigger, i just want some opinions on the setup, thanks
Old Jun 13, 2008 | 04:52 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: my setup, question? (seldon)
PR3 head/B18A/B Block
STD = 12.825536009218106
.25 OS = 12.88971493738735
You are pushing the high 12's for compression so tuning will be critical for you to run safely and make power on pump gas. What kind of tuning will you be using and who will be tuning it for you?
Also leave your valves the stock size.
Old Jun 13, 2008 | 05:02 PM
seldon's Avatar
i'll be getting it tuned at JD Racing in New Brunswick, which tuning software is still up in the air, any suggestions?
Old Jun 13, 2008 | 05:14 PM
00Red_SiR's Avatar
All Motor Mentor
Danny has tuned lots of different cars on different tuning systems so I would email or call him to see what he suggests you use. If you haven't installed the ctr pistons yet maybe you should consider using some JDM ITR or JDM b16a pistons instead. Those cams you're using certainly don't require that amount of compression to make power. Less compression would give you more room to move when tuning.
Old Jun 13, 2008 | 05:19 PM
seldon's Avatar
cool man, thanks a lot
Old Jun 14, 2008 | 06:59 PM
le diable's Avatar
danny will prob try to get you to use ectune as he's starting to tune with this
bertsb18hatch
14
Dec 8, 2010 10:35 PM
B16CRXT
41
Oct 23, 2008 05:40 PM
JDMH22Prelude
Jun 22, 2006 09:44 AM
LilCivic04
Jan 15, 2006 10:54 PM
WinnyH
Jul 17, 2001 03:11 PM
