Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Suspension bolt help!!
Old Jun 13, 2008 | 01:19 PM
RedEG8's Avatar
Default Suspension bolt help!!
K well im taking out my rear shocks to put in new coilovers but the driver side bolt wont seem to budge (Like its on there pretty good) ive even tried using my air gun as well and wen you tryin turnin it the rubber sealant inside kinda moves with....soo now what other options can i try using???
Old Jun 13, 2008 | 01:30 PM
burke420's Avatar
Default Re: Suspension bolt help!! (RedEG8)
get a longer bar to get some leverage... or make sure that that isnt the bolt connected to the trailing arm... thats not supposed to move!
Old Jun 13, 2008 | 01:35 PM
em2power's Avatar
Default Re: Suspension bolt help!! (burke420)
also you can try jacking up the control arm, to relieve the pressure on the strut asembly. Use some lubricant to loosen the bolt.
Old Jun 13, 2008 | 02:28 PM
fireisfun135's Avatar
yea what they said ^^^and you could put a long pipe on the end of ratchet to give you more leverage
Old Jun 13, 2008 | 09:01 PM
InanimateCarbonRod's Avatar
Default Re: (fireisfun135)
Try using a pry bar under the head of the bolt while at the same time backing it out with the impact wrench. That and a lot of PB blast.
Old Jun 13, 2008 | 09:33 PM
Eyger's Avatar
Lots of wd40 on it, then get good leverage, it's all about leverage, seriously. If there's any one thing I've learned while working on my suspension, it's that you need leverage to get stubborn bolts.
Old Jun 13, 2008 | 10:23 PM
whitexpinoy's Avatar
i just did my suspension today and had the same prob... grabbed me some wd-40, posed my legs in a good position and pulled as hard as i could hahaha i only weigh 140.... step your **** up son!
Old Jun 14, 2008 | 03:56 PM
K24_Y61P's Avatar
Default Re: (whitexpinoy)
It could be seized, mine were. Matt and I tried everything to get them off. I eventually had to take it to the shop.
bboygreddy
Aug 23, 2006 01:04 PM
WNT KCH
Oct 13, 2005 10:14 PM
Xerxes3333
Aug 2, 2004 06:24 PM
95 Gizzer
Jan 30, 2003 10:26 AM
92Si
Jul 25, 2001 10:37 AM
