Having Problems with Rotor/Pad install and the Pin Boot not moving.
Old Jul 17, 2002 | 11:05 AM
DamonBoost's Avatar
New User
Default Having Problems with Rotor/Pad install and the Pin Boot not moving.
I am installing new rotors and pads and having problems with the rear pin boot (the bolt that connects the two parts of the caliper together). It doesnt seem to want to compress like the other one and I cant get it down. Because of this i cant get the rotor to fit between the pads. The other one went on easy. I have already screwed the piston screw thingy all the way down so that it has went back in the boot, you cant even see the damn thing anymore! Any help needed would be appreciated.. Thanks in advance guys.. I am about to have a "come apart" here
Old Jul 17, 2002 | 11:34 AM
Spade's Avatar
Default Re: Having Problems with Rotor/Pad install and the Pin Boot not moving. (DamonBoost)
EDIT: Hrm......are the pads sitting flush against the caliper?
[Modified by Spade, 12:36 PM 7/17/2002]
Old Jul 17, 2002 | 11:44 AM
DamonBoost's Avatar
New User
Default Re: Having Problems with Rotor/Pad install and the Pin Boot not moving. (Spade)
the back pad is past flush.. the front pad is all the way against the caliper as well. it cant go any further back.
Old Jul 17, 2002 | 03:31 PM
DamonBoost's Avatar
New User
ttt
Old Jul 17, 2002 | 04:04 PM
Adi Radoncic's Avatar
On Fire!
It is very posible that the pin inside the bracket that holds the caliper around the rotor has rusted up and seazed. If you want to fix it you need to find some way of pulling the pin out and than cleaning all of the rust inside the hole on the bracket and than buy yourself a couple of new pins and throw the rusted one away...
Or you can just buy a brand new bracket all together and some new pins put it all together and your done...!!
Hope this helps.
Adi
Old Jul 17, 2002 | 07:18 PM
DamonBoost's Avatar
New User
Default Re: Having Problems with Rotor/Pad install and the Pin Boot not moving. (newgsr)
Hope this helps.
Adi
Yep that was it!! I finall y got the bolt out and it was all rusted and seized in there.. I took the bolt and cleaned it up then redrilled the hole... good as new.. took me 2 days to get it all figured out. thanks for all the help guys..
Old Jul 18, 2002 | 06:22 AM
Mover's Avatar
I had the same problem... It was causing the car to pull slightly to the opposite side under high speed braking
DB1_559
Oct 1, 2006 08:27 PM
ProjektR
Mar 11, 2006 02:15 PM
Import_Fan
Suspension & Brakes
Apr 21, 2005 06:20 PM
st0ne
11
Jun 4, 2003 03:41 PM
Kamin
Jun 13, 2002 03:38 PM
