Need help With my EH!
Old Jun 13, 2008 | 12:38 PM
mark_is_gay's Avatar
Default Need help With my EH!
hey guys i have a 92 civic si hb. It has a non-vtec 1.6 liter sohc. I am having this issue when the car warms up it wont start at all. If i drive in and it warms up, then turn it off to go in the store it will start but wont stay on. If i leave it in the sun for to long and then go to start it, it wont start at all. I was thinking it might be my dizzy or dizzy wires...what do you guys think? really need help with this, its my only car and i need it to start working right! thanks.
Old Jun 13, 2008 | 12:45 PM
Default Re: Need help With my EH! (mark_is_gay)
main relay problem? should i buy a new one?
Old Jun 13, 2008 | 03:30 PM
riceburnerryan's Avatar
do you have any CELs? if not i would check all the wiring and make sure none of it is corroded and make sure all the grounds are clean
Old Jun 13, 2008 | 04:40 PM
batallic's Avatar
main relay
Old Jun 13, 2008 | 09:42 PM
dividedas1's Avatar
Default Re: (batallic)
check the
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic &raquo;</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
and also the fuel pump relay.
cant remember which one it was but my buddy's 92 four door did the SAME thing. and he replaced those to things and no more worrying about not being able to
I would say checking those two things would be a good place to start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">do you have any CELs? if not i would check all the wiring and make sure none of it is corroded and make sure all the grounds are clean</TD></TR></TABLE>
Definately check all your wiring too. I don't think he would be throwing a code for the main relay or the fuel relay. Atleast the four door we had wasn't.
collkid
13
Sep 16, 2015 09:10 PM
06turbocivic18
Oct 13, 2009 10:04 AM
H22Ej1
Jun 14, 2007 09:30 PM
Donkey85
Dec 6, 2004 05:45 PM
CXHatchback
Nov 23, 2004 11:32 AM
