Mini me swap confusion!!! Sorry faq didn't help...
I wanna do a mini-me swap on my '90 CRX european model. My engine is a D16Z5 all stock.
My question has to do with choice of heads. Iv heard i need:
- A VTEC head: Which model can i use? Does any 1.6 VTEC head fit mine? I'v seen one from a DEL SOL. Will that fit? Which head is BEST to use, and how do i identify it (from ebay for instance). Can i use any 1.6 VTEC head?
- Gasket set from VTEC head
- Timing belt from VTEC head
- Valve cover and gasket
- RPM activated switch or VTEC controller: Can this be any 1.6 VTEC controller or switch?
- Adjustable fuel pressure regulator
- Timing light etc
Basically, i have to buy these parts from Ebay.com as i'm in Scandinavia and VTEC heads are rare. Is there another place than Ebay where i can get ALL the parts for this swap. Can anyone sell me a swap 'kit'? Oh, and at has to be 'cheap' as i'm a mechanical engineer student
Sorry about posting this 'common' question, but i just got confused with the faq section. But, thats what a forum is for, right
Thanks guys!
Dave
- Timing light etc
Thanks guys!
Dave
the D16Z5 being a DOHC engine cannot be converted to VTEC - there are no DOHC D16 VTEC engines - SOHC VTEC D16 heads won't work on the DOHC block - the Del Sol VTEC is a B-series engine - completely different from D-series
just keep the Z5 and put a pair of bigger camshafts in it and bore out the throttle body to 60mm - a 4.25 final drive transmission would also be a big help, if you don't already have one - lots of things you can do to it for the $2500 (U.S.) that it would take to swap to B-series
tequila_sunrise
Jan 25, 2008 02:55 PM
