where is the thermostat on a crx si d16a6
hi im just trying to figure somthing out. after doing a head gasket change. and my temp gauge isnt reading. so i was trying to locate the thermostat
if you fallow the lower hose on your radiator up to your block, the housing there that it conects to will hold your thermostat, take out the two bolt that hold it place with a 10mm socket and you will find it inside the housing, make sure you use honda bond or a type of sylicon sealent when you but it back togeter, and dont for get to buy coolant....
new_climber
Dec 14, 2008 10:07 PM
1991, 1991crx, 85, change, changing, crx, d16a6, honda, installation, location, sending, si, temperature, thermostat, unit
