Wastegate on divided housing turbine - how?
Old Jun 13, 2008 | 07:55 AM
kb58's Avatar
Banned
Default Wastegate on divided housing turbine - how?
So I want to use a divided housing (twin-scroll) on my turbo to minimize turbo lag. The catch is that the wastegate is supposed to bleed off all four cylinders.
Research shows that the right way is using two wastegates, but I'm trying to keep things simple. Why can't I run a divider in the tube leading to the wastegate, right up to the wastegate valve? I was told that it won't work because it'll choke off the flow but I'm not sure I agree with that. If half the flow comes from two cylinders, having half the wastegate to flow through should be fine.
Is my thinking right on this? How have you guys dealt with this situation?
Modified by kb58 at 9:02 AM 6/13/2008
Old Jun 13, 2008 | 10:00 AM
morgan@synapse motorsport's Avatar
Default Re: Wastegate on divided housing turbine - how? (kb58)
its been done, and it can work fine, but like you said it isnt the most ideal setup.
Old Jun 13, 2008 | 10:13 PM
reaction360's Avatar
Default Re: Wastegate on divided housing turbine - how? (mike@synapse motorsport)
the ones I've seen, have wastegate necks that come around and join up into one wastegate.
tony413
Aug 3, 2008 09:12 AM
wicked2night
Jan 24, 2007 09:32 AM
jdmtuner_00
Jan 5, 2006 10:04 PM
sixphak
Welding / Fabrication
Feb 15, 2005 06:47 PM
WEPN R
Mar 2, 2004 10:16 AM
