crx d16 a6 problem. put in a new head gasket kit and wont run right.
Old Jun 12, 2008 | 08:13 PM
juhnke's Avatar
Default crx d16 a6 problem. put in a new head gasket kit and wont run right.
i recently installed a new head gasket kit. im pretty sure i did everything right. im just not exactly sure on the timing crap. anyways... i put the motor back together and first i had to rotate the distributor 180 degrees before it would start. then when it started the engine check came on almost immediately and it started bogging at 3500 rpm when revved. when it is bogging it isnt just a constant bog the bogging fluctuates if the throttle is held on. also, the engine runs fine before the engine check light turns on
Old Jun 12, 2008 | 08:53 PM
1 Fly SI's Avatar
Default Re: crx d16 a6 problem. put in a new head gasket kit and wont run right. (juhnke)
What code is the ecu shooting? Sounds like your in limp mode.
Old Jun 13, 2008 | 05:05 AM
juhnke's Avatar
Default Re: crx d16 a6 problem. put in a new head gasket kit and wont run right. (1 Fly SI)
how would i check my ecu codes? can you check them with a d16 not vtec?
Old Jun 13, 2008 | 09:22 AM
juhnke's Avatar
also, i figured out that the thermostat doesnt work. my engine thermostat when im running my gauge stays at zero. could this be part of the problem? wiring issues?
Modified by juhnke at 10:40 AM 6/13/2008
Old Jun 13, 2008 | 10:26 AM
JDM-JAMES's Avatar
check all your plugs to the head
Old Jun 13, 2008 | 10:33 AM
JCRXTURBO20916's Avatar
let start over, when you taken the head off did you set your cyl #1 to tdc, that the piston closes to the timming belt, make sure that was all the way up, when you put the belt on did you set your cam gear to tdc. that where the cam gear is pointing up, it will have a mark that say up, and the other two line on each side of the cam gear lines up with the top of the head horizontle if its not at those mark, redue the timming. Was the engine running fine befor you did the head job ? and did you have any check engine light on befor...
Old Jun 13, 2008 | 10:40 AM
juhnke's Avatar
Default Re: (JCRXTURBO20916)
the engine check light was not there before i did the head gasket replacement. the engine ran fine besides burning some antifreeze. its just running crappy now after the head gasket.
i had my pistons 1 and 4 at tdc when i performed the timing but im not sure about the cam gear.
Old Jun 13, 2008 | 10:46 AM
juhnke's Avatar
yes i checked all my plugs and replaced the wiring to one of the plugs. i didnt mess with the thermostat housing before i did the gasket replacement, so it should be fine now, but its just not reading.
Old Jun 13, 2008 | 10:55 AM
jlicrx's Avatar
Default Re: (juhnke)
make sure you have timing belt on right - D16A6 is not the same as D15 engines - D15 cam gear marks line up with top of head - D16A6, you use the 3rd mark at about 7 o'clock and line it up with the mark on the inner timing cover
Old Jun 13, 2008 | 11:07 AM
juhnke's Avatar
Default Re: (jlicrx)
k im going to redo my timing right now and see how it turns out
Old Jun 13, 2008 | 11:16 AM
juhnke's Avatar
where is the white mark that lines up with the pointer on the timing belt cover. is it on the belt or what. i cant find it
Old Jun 13, 2008 | 01:19 PM
it should be on the crank pully,
Old Jun 13, 2008 | 01:29 PM
juhnke's Avatar
its on the pully, not the belt?? im not seeing any white marks
Old Jun 13, 2008 | 02:55 PM
1 Fly SI's Avatar
Look on the ecu, it should have a red led light that flashes the code.
Old Jun 14, 2008 | 04:09 AM
juhnke's Avatar
yup the ecu flashes 4 lights then pause then 4 lights and repeats that process... isnt that crank position sensor?
Old Jun 14, 2008 | 11:51 AM
Marcos Barrios's Avatar
yup
code 4 is crank shaft position sensor
Old Jun 14, 2008 | 12:55 PM
fin781's Avatar
Default Re: crx d16 a6 problem. put in a new head gasket kit and wont run right. (Marcos Barrios)
on your crank pulley there are three marks beside one another, about 2 tinkles over there is another. the seperate mark is your tdc mark, take a white paint marker and mark it. when the motor finally runs get a timing light and and the pointer should be hitting on the middle notch of the 3.
Old Jun 15, 2008 | 06:07 AM
juhnke's Avatar
Default Re: crx d16 a6 problem. put in a new head gasket kit and wont run right. (fin781)
there isnt any marks on my crank pulley, you mean the cam gear for the timing belt right.
ive timed it correctly about 3 times and then gone back and forth a tooth about 5 times so i have no clue what is wrong
Old Jun 15, 2008 | 06:12 AM
~sp33~'s Avatar
EFB055
Default FV-QR
There should be marks on your crank pulley, they're only small and may be covered in scunge, but they definitely SHOULD be there.
Old Jun 16, 2008 | 07:39 AM
ok try this, if your not sure about your timming, take out spark plug #1 that the plug closes to the timming belt. cut up a hager metal or plastic up. just make sure you save the logest peice, you will need that to stick into you cyl. JUST MAKE SURE YOU DONT SCRATCH YOUR CYL WALLS IF YOU USE A METAL HANGER. take off you timming belt, and turn the crank till you see the hanger hit tdc. then turn the cam and mark that up with the point, slip the belt on, your crank sensor is located in your diz. give that a shot, and see how that works.
Old Jun 18, 2008 | 08:20 PM
1990CRX_Si's Avatar
The mark you are looking for is the fourth, way over to the right. I moved the pulley away from TDC so all 4 marks could be seen in this photo
[edited to add text]
Modified by 1990CRX_Si at 9:28 PM 6/18/2008
Boststin
Honda Civic (2001 - 2005)
10
Jul 18, 2017 05:54 AM
Mike95Civic
13
Feb 20, 2012 01:56 PM
avatar1
16
May 27, 2010 06:16 PM
si1320civic
Apr 11, 2009 10:50 AM
DustinPennington
Apr 22, 2008 02:44 PM
