Turbo EG GSR project!
Hey all, ive got a 94 EG sedan with a GSR motor and due to the buyer backing out, i now want to keep the car.
I am looking at getting either a Revhard or Peakboost kit. Has anyone had any dealings with these kits before? if so what feedback do you have?
2. The mods on my engine so far are: Exedy clutch and flywheel, Skunk2 IM, ITR throttle body and Mugen headgasket...
using the T3/TO4E Garret turbo, anyone used this? what sorta Rpm does it spool up and hit full boost etc? and does anyone know what sorta power ill be looking at on 7psi?"
Thanks alot
Christian
Thanks alot
Christian
cant tell you what the turbo will do for your set up.
the same exact set up in 2 different cars will produce two different whp.
but i switched over to a peakboost partial system from my buddy and i like no problem with manifold or downpipe.
id go with peakboost to get the equal length manifold if i had to choose between those 2
and your going to need fuel pump ,injectors and tuning
Its time to read the FAQ's..........you have a lot of questions (in this thread and other threads) that will be better answered if you take the time to research it yourself.
There are a LOT of people who make turbo kits and are reputable..........
Full-race
Peakboost
AFI
Spoolinperformance
Boostfed (forgot which kits he sells)
There are a lot more, these are the ones off the top of my head. You could also build your own kit from scratch or start off with a mani, dp and turbo from one of these vendors. Time to research and then you will be able to make an informed decision.
Full-race
Peakboost
AFI
Spoolinperformance
i am doing alot of research, its just that im after other peoples opinions after using the products etc to see if they are good quality, no headaches etc...
as for the actual turbocharger questions, im just a little noob on the little specs etc haha
I had a t3/t04e on my gsr..i think it was .63 turbine/.70 comp. I had a tial 38 wg and there was supposed to be an 8 psi spring in it but i'm guessing it was like 4psi, anyway i used that combo with a blitz boost controller and it hit 8 psi at like 5000, idk if it was just the combo or the turbo size or what. I was also using a ssautochrome manifold that i got for cheap (that never cracked
) but i would go with peakboost or full-race or something if i were you. One of my buddies has a gsr with a full-race ramhorn and a 57 trim and it spools up by like 3000 on 8 psi, its very fun!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTi_b0i »</TD></TR><TR><TD CLASS="quote">well not that ive seen so far...
noob question, but is there much of a differance in 38mm wastegate and 44mm?
Yes, there's the 38mm, 40mm and 44mm.
thanks alot for the feedback guys! much appreciated!
RickDrizzle, i know they come in those sizes, i was just wondering what the differance betweeen them is...
was wondering if at all anyone had bought a FullRace kit? and what they thort of it? the kit looks like its real quality! and has quality brand named parts! duno bout the manifold tho...
Man, once again............SEARCH AND READ THE FAQ's!!!!
If you want to know what people think about FR kits then search!! It's time you did some research and figured out what you think for yourself. I already gave you 5 options of kits from people who make good **** and are reputable. Why ask if you aren't going to listen??? If you are just going to ask about every kit manufacturer around you are just waisting people's time. Do some searching on here (the RED button tittled SEARCH) in the upper right of this page. Make sure you check the "archived" button to. If there is anything people aren't scared to give on H-T, it's their opinions. People write about every kit you could ever purchase. SEARCH!! GL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTi_b0i »</TD></TR><TR><TD CLASS="quote">thanks alot for the feedback guys! much appreciated!
RickDrizzle, i know they come in those sizes, i was just wondering what the differance betweeen them is...</TD></TR></TABLE>
a 44mm wastegate has less chance of creepin' than a 38mm. that's the difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">
a 44mm wastegate has less chance of creepin' than a 38mm. that's the difference.</TD></TR></TABLE>
That is not entirely correct. A bigger wasted gate is not always a good thing it just depends on your setup and how much boost your on.
Thanks alot guys!
Thanks for the honest advice Keyser. I have searched but dont really seem to be finding what i want, im still getting used to this site because its alot different to the ones im used to haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx »</TD></TR><TR><TD CLASS="quote">
That is not entirely correct. A bigger wasted gate is not always a good thing it just depends on your setup and how much boost your on. </TD></TR></TABLE>
Of course the setup will always come into play. But that's how it generally works. Try telling the guys with a 35R that's running a moderate amount of boost to use a 38mm.
Well it seems ive narrowed it down to a Full Race kit, Either a stage 1 GT AC kit OR a Stage 2 AC Kit both Pro Street kits.
All i have to do is find out what turbo would suit me better.
The Stage one GT kit uses the "GT2860RS Ball Bearing Turbo with T3 housing"
and the stage 2 kit uses the "T3/60-1 Turbo"
id like the turbo to start boosting around 3000rpm or a little before that but i want it to keep making power till 8000rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTi_b0i »</TD></TR><TR><TD CLASS="quote">Well it seems ive narrowed it down to a Full Race kit, Either a stage 1 GT AC kit OR a Stage 2 AC Kit both Pro Street kits.
id like the turbo to start boosting around 3000rpm or a little before that but i want it to keep making power till 8000rpm</TD></TR></TABLE>
How much power are you looking for? The GT2860 would be my choice on a responsive, quick spooling, sub-375 whp street application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTi_b0i »</TD></TR><TR><TD CLASS="quote">I have searched</TD></TR></TABLE>
^^^ Really?
https://honda-tech.com/zero...age=1
68 pages of Peakboost kit fitment/numbers.....Ken from peakboost answers a lot of questions in the thread......
Full race........
https://honda-tech.com/zerothread?id=2149529
A little 4 pag'r
https://honda-tech.com/zerothread?id=2186100
^^^ Question about f-r kit and peoples opinions.......
https://honda-tech.com/zerothread?id=1882902
^^^Another short thread about f-r kits
https://honda-tech.com/zerothread?id=1536159
^^ Another f-r kit thread......even I make a cameo in this one....
There are a lot more, but I don't feel like I should have to spend the 10 minutes required to find the pertinent threads.
GL.
^^^ Really?
Full race........
A little 4 pag'r
GL.
