please help!! strange clutch problems..
ok, i've spent a great deal of time searching for the solution to this, but i haven't found anything that really helps me out w/my problem (so don't flame me
anyways, here's the deal. this problem only occurs after driving my car for a while (i.e. 10-15 minutes). what happens is that i get a loud creaking/groaning noise when i push in the clutch pedal. it is coming from somewhere in the engine bay. also, the pedal feel changes -- it gets harder to push, and is not smooth feeling like when the car is cold.
i've already changed out the slave & master cylinders, but that didn't do sh*t.
it seems to me that something is heating something up, causing this annoyance (i must note that this problem started to happen after i took off the upper heatshield of my cat - damn noisy rattle) since it only starts to happen after driving around for a while.
the clutch still engages at the same point, there is no slippage, and it is still easy to move the shifter into every gear. also, there is no grinding.
what the hell is going on?? i've already spent over 300 bucks,
and i don't want to drop the tranny, only to have this problem come back again!! any feedback is much appreciated!!
).anyways, here's the deal. this problem only occurs after driving my car for a while (i.e. 10-15 minutes). what happens is that i get a loud creaking/groaning noise when i push in the clutch pedal. it is coming from somewhere in the engine bay. also, the pedal feel changes -- it gets harder to push, and is not smooth feeling like when the car is cold.
it seems to me that something is heating something up, causing this annoyance (i must note that this problem started to happen after i took off the upper heatshield of my cat - damn noisy rattle) since it only starts to happen after driving around for a while.the clutch still engages at the same point, there is no slippage, and it is still easy to move the shifter into every gear. also, there is no grinding.
The same thing is happening to me. After about 10 minutes and I'm at operating temp, I get the creaking. It's probably a lubriacation problem, but they said my master cylinder is leaking...Hope this fix's it, otherwise I need to start greasing everything.
I have had this happen twice...both times it was because a spring or two in the clutch pack broke out of it's housing. If I remember right, the spring would then get lodged between the pressure plate fingers and and the clutch disc. Sometimes I would have troubles, other times I didn't. But it definately made noises and make the clutch feel wierd at times.
