RHD Rear Crossmember
Does anyone know if rhd rear crossmembers are the same from a d series or b series front clip? Like the mounting points for the rear mount?
I guess i should add that im doing a rhd conversion and keeping my sohc. I just need to know if i can use a SIR (b16) crossmember for the conversion and still be able to use my rear mount for my d-series.
if its a b series crossmember off a jdm then it wont fit the mount will fit but the hanger will not work it will be to short the jdm bseries mount sits further back to accomidate the b series from the factory i have had this problem before had to get some fab work done
dang, i wish i knew for sure. I have people saying yes and no. The reason i ask is cause HMO has 5 clips, 4 b16 clips, 1 sohc zc clip. I was gonna buy the sohc zc clip cause i knew it would work for sure. But the dash in that clip is junk as you can see. If i knew the b16 clip would work i would have my choice between 4 other dash's.
I asked that, just waiting on a reply. Hopefully steve will swap me a good dash
Modified by CRX MASE at 12:23 PM 6/14/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro »</TD></TR><TR><TD CLASS="quote">nope no difference because they are both for ZCs that top one is not from an SiR</TD></TR></TABLE>
Youre right i forgot that car was once a zc. I saw it had a bseries in it and thought sir.
I wish i could figure this out for sure, i dont want to order a clip with a shitty dash. Hopefully steve can swap it out.
dem0nk1d
Nov 21, 2008 09:44 AM
IOSUA
34
Mar 5, 2007 12:02 PM
cxVtecC1
Jun 3, 2005 06:48 PM
