Wideband permanently installed...how long do you O2 sensors last?
Old Jun 12, 2008 | 12:27 PM
champLSinteg's Avatar
Default Wideband permanently installed...how long do you O2 sensors last?
I picked up a plx m300 a few months back but installed it only about 3 weeks ago. I have it in my car permanently and I have used it for a total of maybe 400 miles. It is now only reading a max of 16.8 and a min of 13.8 afr so I think the sensor has taken a dump. I just bought a replacement but if its only going to last a couple thousand miles of use then I might just uninstall it for now because they are pricy. How long have you guys been running your wideband sensors daily driving?
Old Jun 12, 2008 | 12:49 PM
awdgsx96's Avatar
Default Re: Wideband permanently installed...how long do you O2 sensors last? (champLSinteg)
Check your ground or something. Is it reading accurately while in that range?
TiAL's Avatar
let me guess, the sensor is not 24" or more from the turbo?
Old Jun 12, 2008 | 12:51 PM
Jim Truett's Avatar
How close is it to your turbine outlet? I hope you don't pay more than $78 for them.
Old Jun 12, 2008 | 01:34 PM
extralargenog's Avatar
Default Re: Wideband permanently installed...how long do you O2 sensors last? (Jim Truett)
Mines about 18" down from the turbo.... I run ALOT of leaded gas through it, and Get about 6K per sensor... Theyll get lazy and start refreshing slowly, then hang out on the lean end... If its refreshing quickly and reading rich, check your power...
Old Jun 12, 2008 | 02:24 PM
91civicDXdude's Avatar
I've tuned multiple cars with my LM1 and i'm going on over 10k miles in my car steady with no problems
Old Jun 12, 2008 | 02:27 PM
Default Re: Wideband permanently installed...how long do you O2 sensors last? (TiAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">let me guess, the sensor is not 24" or more from the turbo?</TD></TR></TABLE>
Its about 18in from the turbo i think. I have to check that again. Should it be at least 24in from the turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">Check your ground or something. Is it reading accurately while in that range?</TD></TR></TABLE>
I'll check the ground when I get home. On decel it used to read lean because the injectors shut off but now it reads a max of 16.8 when I boost it only goes down to 13.8. It is very laggy too!
I first noticed this on the drive home from the track on the 31st. The lowest it would read was mid 12's and mid 17's was the highest. I didnt drive it until 3 days ago and I noticed it was now worse.
Old Jun 12, 2008 | 02:43 PM
how much leaded **** you run through it??? It WILL dramatically decrease the life... compounded by it being to close if it is.
Old Jun 12, 2008 | 02:46 PM
Default Re: Wideband permanently installed...how long do you O2 sensors last? (extralargenog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">how much leaded **** you run through it??? It WILL dramatically decrease the life... compounded by it being to close if it is.</TD></TR></TABLE>
None! I've never run leaded fuel. All driving and racing has been done on 91oct.
Modified by champLSinteg at 5:52 PM 6/12/2008
Old Jun 12, 2008 | 05:52 PM
Jim Truett's Avatar
What's your EGT under load?
Old Jun 12, 2008 | 06:42 PM
blackeg's Avatar
you've gotta move the sensor further back in the exhaust. i used to have mine real close like maybe 7 inches from the turbine and it got to the point where i smoked a sensor in like 200 miles. now i run mine about 6 inches behind the oil pan like right under the xmember. last sensor i had lasted a good 5-6000 miles.
its better to be safe than sorry and buy a new sensor, then move its position. its not worht toasting a motor over a 60 dollar o2 sensor
Old Jun 12, 2008 | 07:46 PM
Default Re: Wideband permanently installed...how long do you O2 sensors last? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">What's your EGT under load? </TD></TR></TABLE>
I dont know what my egt is.
I'll move the sensor back to near the stock location. Hopefully I dont kill this one.
Thanks
Old Jun 12, 2008 | 09:17 PM
omniscient's Avatar
The sensor that came with my Lc-1 kit lasted about 900 miles before it got stuck around 14.7-14.1 at all times. The sensor is right before the flex on my downpipe, behind the oil pan.
I bought a replacement bosh and so far it's been fine, about 1500 miles on it.
Old Jun 13, 2008 | 04:02 AM
RedR's Avatar
Default Re: Wideband permanently installed...how long do you O2 sensors last? (omniscient)
12k miles on mine, still works fine
Old Jun 13, 2008 | 05:05 AM
Topdawgg's Avatar
where can i buy a replacement sensor for my innovate for a good price?
Old Jun 13, 2008 | 09:18 AM
mike93eh2's Avatar
ive been running nothing but leaded gas on my engine for the past year and a half or more and my plx m300 and bosch sensor are still working perfectly. my sensor is 24" downstream from the turbo.
Old Jun 13, 2008 | 09:21 AM
mike93eh2's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">where can i buy a replacement sensor for my innovate for a good price?</TD></TR></TABLE>
$69.68
http://streetrays.com/plx-devi....aspx
innovative usually uses the type b i think. they also have the type a.
Old Jun 13, 2008 | 06:04 PM
joppe's Avatar
20000ML with some abuse, running with out lm1, some oil with broken turbo/engine, some very rich afr:s like 9:1. Still working great. Innovate lm1+xd1.
Old Jun 13, 2008 | 07:09 PM
Default Re: (joppe)
AMAZON.com has em for 52 bux
Old Jun 14, 2008 | 10:50 PM
Default Re: (extralargenog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">AMAZON.com has em for 52 bux</TD></TR></TABLE>
Damn! It would have been nice to know this 5 days ago! I would have saved myself almost $30.
Old Jun 15, 2008 | 08:35 AM
welfarepc's Avatar
ive had mine (bosch lsu 4.2 with lc1) installed for about 9 months. Was just on the dyno and it was reading exactly the same.
ive calibrated it two or three times since install.
Old Jun 15, 2008 | 12:20 PM
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">ive had mine (bosch lsu 4.2 with lc1) installed for about 9 months. Was just on the dyno and it was reading exactly the same.
ive calibrated it two or three times since install.</TD></TR></TABLE>
how do you calibrate the sensor?
Old Jun 15, 2008 | 09:08 PM
Default Re: (champLSinteg)
Why would the sensor go out prematurely if installed too close to the turbo?
Old Jun 15, 2008 | 10:50 PM
welfarepc's Avatar
i cant remmeber how to calibrate it... i remember u ground it out, and then do something... with the sensor in the air uninstalled...
check out the innovate website, there is a user manual for the LC1 on there
the sensor will wear prematurly if it is too close to the turbo because it will get too hot.
MK Ultra
Jun 14, 2006 04:31 PM
Maxime
Feb 24, 2004 11:05 AM
integranator
Sep 19, 2003 09:42 PM
ITR 2K
Feb 2, 2002 11:25 AM
