finish with itr swap now car studders at low rpm
Old Jun 12, 2008 | 09:16 AM
CRX_RR's Avatar
Default finish with itr swap now car studders at low rpm
just finish a jdm itr engine in my crx. i can't check cell because i have no light to check. so idk if i have bad wiring. but i sent my wire in threw rywire, so sure that can't be it. if theres another way to check for cell? don't know if i have bad vacuum or something.
here's the vid
http://s172.photobucket.com/al...9.flv
Modified by CRX_RR at 4:40 PM 6/13/2008
Modified by CRX_RR at 7:42 PM 6/13/2008
Old Jun 12, 2008 | 09:34 AM
CRX_RR's Avatar
Default Re: finish with itr swap now car studders at low rpm (CRX_RR)
i'll post a video up tommorow
Old Jun 13, 2008 | 03:41 PM
CRX_RR's Avatar
here's the vid.
Old Jun 13, 2008 | 06:10 PM
CRX_RR's Avatar
any help
Old Jun 13, 2008 | 07:24 PM
saikouEF8's Avatar
sounds like the iacv and fitv need some cleaning... as far as the fitv goes.. the white screw inside of it needs to be threaded all the way in...
https://honda-tech.com/zerothread/1564019 - fitv
https://honda-tech.com/zerothread/1575913 - iacv
Modified by saikouEF8 at 8:35 PM 6/13/2008
Old Jun 13, 2008 | 07:54 PM
playaP's Avatar
your best bet is get the CEL working... maybe find out what wire runs out the ecu to the stock CEL and connect a led or something..
Old Jun 14, 2008 | 08:43 AM
snowseeker's Avatar
Default Re: finish with itr swap now car studders at low rpm (playaP)
I don't know why but I kinda like to door ajar sound on ef's. beep beep beep beep beep beep beep beep.
OP, unplug your iacv and see what the motor idles at, it should be around 600rpmish.
Old Jun 14, 2008 | 10:24 AM
CRX_RR's Avatar
Default Re: finish with itr swap now car studders at low rpm (snowseeker)
yes it goes to 600. another ? my oil light comes on after a while when i drive. i want to know if i could still drive it for a long time and not ruin any of my internal parts. And what are the risk of driving it?
Old Jun 14, 2008 | 11:41 AM
Marcos Barrios's Avatar
I wouldn't risk it man
just put oil in it
or is there something stopping you from doing that?
Old Jun 14, 2008 | 11:44 AM
CRX_RR's Avatar
Default Re: finish with itr swap now car studders at low rpm (Marcos Barrios)
there is oil in it. i put 4 quarts in it.
Old Jun 14, 2008 | 01:34 PM
CRX_RR's Avatar
anybody knows for the vtec solenoid...... for the oil pressure switch, how many wires go to it..mine only has one. should there be two. idk that maybe why it has the oil light on.
jdmcar
May 4, 2006 03:05 PM
Chalupa R
Sep 11, 2002 05:00 PM
t
Nov 14, 2001 08:36 PM
ghettoracer
Oct 30, 2001 04:23 PM
