car wont start! ecu problem
Old Jun 11, 2008 | 09:31 PM
00si_guy's Avatar
Default car wont start! ecu problem
i was hooking up my apexi neo and all that i had connected were the 2 hot wires, 2 ground wires, and the rpm wire. everything was working fine but when i went to crank it, it would not turn over....i checked all the wires to make sure they had good connection and they did...so now the apexi neo does not even come on and also, there are NO HOT WIRES in the ecu. NONE AT ALL!!! what is wrong????? main relay or what? please help me!
Old Jun 16, 2008 | 11:03 AM
vtecb18c's Avatar
Default Re: car wont start! ecu problem (00si_guy)
could be the main or you fried your ecu...did you remember to take the neg terminal off when you were installing you apexi controller
SDT Project EF
13
Sep 7, 2006 07:44 PM
3.point.2
Feb 2, 2006 01:02 PM
crx88fast
Dec 30, 2005 05:19 PM
LoseRPunKx182
Aug 9, 2005 02:53 PM
93ludesiCK
Jul 23, 2004 01:28 PM
