b16a2 sensors are connected , there is fuel pressure , the engine check light is not going of so i g
Old Jul 17, 2002 | 08:28 AM
nosmas's Avatar
Default b16a2 sensors are connected , there is fuel pressure , the engine check light is not going of so i g
b16a2 motor
sensors are connected , there is fuel pressure , the engine check light is not going of so i guess all the plugs are correct. so how do i check for spark if the motor wont start i know the firing order is right but it wont start. but it cranks so what else is the prob . can Ne one tell me how to check if the distributor is ok ? could it be Distributor?..!!!
Old Jul 17, 2002 | 08:32 AM
flat-blk-HB's Avatar
Default Re: b16a2 sensors are connected , there is fuel pressure , the engine check light is not going of so
Check the ground on the thermostat housing. If that is tight then you can pull the plug out and connect it to the wire and set it against your core support and have someone turn the motor over and see if it sparks. Alos check all your grounds.
Old Jul 17, 2002 | 08:51 AM
nosmas's Avatar
if i get sparks then its not the distributor?
[Modified by nosmas, 5:51 PM 7/17/2002]
Old Jul 17, 2002 | 11:46 AM
right. It gets spark I am guessing? I dont know what it could be. what car are you putting the motor in? OBD1,OBD2,OBD0...??
TimelessLlama
Aug 20, 2015 06:40 AM
Kris's turbo
Oct 11, 2011 10:05 AM
HondaRexBoi
May 13, 2008 12:08 PM
4NOWJUSTADX
Jan 22, 2007 07:44 AM
nosmas
Jul 17, 2002 09:47 AM
