Opinion on 9.8:1 compression pistons for boost?
Old Jun 11, 2008 | 08:11 PM
pipe718's Avatar
Default Opinion on 9.8:1 compression pistons for boost?
whassuppp.... i have sent out a b18c gsr block to get sleeved, bored n honed, o-rings and decked. I bored it out to 83mm and ordered the wrong set of pistons but figured i might just keep them anyway, my intentions were buying 10:1 but instead i ordered 9.8:1.... so i was wondering if anybody has had any experience with this compression piston for boost? and opinions would be pretty good also THANKS IN ADVANCE!
Old Jun 11, 2008 | 08:45 PM
b.series's Avatar
Default Re: Opinion on 9.8:1 compression pistons for boost? (pipe718)
you will be okay. u will pobably make more power due to the compression being lower.
Old Jun 11, 2008 | 09:34 PM
TheShodan's Avatar
Moderator
Default Re: Opinion on 9.8:1 compression pistons for boost? (b.series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.series &raquo;</TD></TR><TR><TD CLASS="quote">you will be okay. u will pobably make more power due to the compression being lower.</TD></TR></TABLE>
Lower compression does not mean more power. Just a change in acceleration. You'll be fine with 9.8:1
Old Jun 12, 2008 | 04:02 AM
CRVRX's Avatar
Default Re: Opinion on 9.8:1 compression pistons for boost? (TheShodan)
The lower compression will be easier to tune, however the higher copression will have a little more crisp power out of boost.
I have 9.7 to 1 compression in my Type R and it does make plenty of power.
Old Jun 12, 2008 | 07:27 AM
Schister66's Avatar
Man U FTW
To be completely honest, i dont think you'll notice much of a difference between the 10:1 and the 9.8:1 unless you're comparing dyno charts. Your off-boost acceleration is going to be slightly slower and you'll need a little bit more boost to make the same power as the 10:1, but overall, it should still be very similar. BTW, 9.8:1 is what i'm running on my setup....if it ever runs
Old Jun 12, 2008 | 03:01 PM
champLSinteg's Avatar
Default Re: (Schister66)
83mm with 9.8:1 pistons here! 425whp on pump. I love it! I'm sure you will too!
Old Jun 12, 2008 | 04:55 PM
pipe718's Avatar
sounds good, by the way which turbo did you use to achieve 425whp? ^ thanks for all the opinions and suggestions
Old Jun 13, 2008 | 09:36 AM
Default Re: (pipe718)
I made 425 on a t3/t4 60 trim. Heres my setup...
https://honda-tech.com/zerothread?id=2304585
Old Jun 13, 2008 | 09:54 AM
kb58's Avatar
Banned
Default Re: (champLSinteg)
No one's going to notice a 2% change.
RTst92
Mar 5, 2006 01:56 PM
i20ar
Sep 17, 2005 12:48 PM
TehMoonRulz
May 16, 2005 01:15 PM
madcrossover
Dec 13, 2004 06:40 AM
genop
Sep 17, 2003 10:45 PM
