"HELP NEEDED" 88 Honda CRX SI Air Conditioning
Old Jun 11, 2008 | 06:58 PM
sr65's Avatar
Default "HELP NEEDED" 88 Honda CRX SI Air Conditioning
I have a 1988 Civic CRX SI that I would like to put air conditioning in. Does anyone out there have a very good used or new complete system for sale or know where I might get one???? Thanks, Steve
Old Jun 11, 2008 | 08:17 PM
Jdmtru's Avatar
Default Re: "HELP NEEDED" 88 Honda CRX SI Air Conditioning (sr65)
I have the under the hood portion (compressor, b series in crx bracket, and lines)
Old Jun 11, 2008 | 08:24 PM
Booz's Avatar
I actually have the full AC setup from a 90 crx si that I was parting out some time ago. If it'll work for you let me know and I'll rip the rest of it out (just the lines) and send you some pics. I do know that one line may be bent from when I removed the engine.
Old Jun 12, 2008 | 10:56 AM
sr65's Avatar
Default Re: "HELP NEEDED" 88 Honda CRX SI Air Conditioning (Jdmtru)
Jdmtru, What year CRX did the air conditioning system come out of? Do you think it still works? How much do you want for it? Will I need to get anything else to complete my system? Thanks, Steve
Old Jun 12, 2008 | 11:00 AM
sr65's Avatar
Default Re: "HELP NEEDED" 88 Honda CRX SI Air Conditioning (Booz)
Booz, I'll have to check and see if a 90 CRX system is the same as a 88? Do you have the complete system? Do you think it still works? Thanks, Steve
Old Jun 20, 2008 | 01:28 PM
Booz's Avatar
I do know that when I took it out the air blew out fine. As for it being cold it just needed to have the freon changed in it. I bought an 89 with the exact same problem and all I had to do was take the freon from when the car was manufactured out and put the new (R132 maybe?) in it. Not sure on the numbers as I had to have my mechanic handle the freon.
Edit:
I'm not sure if 90 is compatible with 88, but if it is let me know.
Old Jun 22, 2008 | 03:31 PM
doctorgonzo69's Avatar
Default Sanden retrofit article
The 1988-1991 CRX uses a Sanden TR70 (or Matsushita). Anyway, here's a technical article from the Sanden U.S.A. website that outlines the procedure for a r134a conversion:
http://www.sanden.com/support/retro.html
Old Jun 22, 2008 | 04:03 PM
K2e2vin's Avatar
Someone on carolinahondas.com has a complete CRX one for sale.
Also, you can just use Freeze-12; a R12 substitute, instead of converting.
Old Jun 22, 2008 | 05:29 PM
IndySporty's Avatar
Default Re: (K2e2vin)
There's multitudes of EF's in my local junkyard with A/C. The whole setup could be had for around 100 bucks. Then 100 bucks for the honda dealer to evac and recharge it.
sr65
Jun 12, 2008 08:43 AM
JDM_d15b_eg8
Jun 12, 2007 11:31 AM
moocowman
Jul 22, 2002 05:30 PM
jc836
May 24, 2002 09:59 PM
