ticking sound in motor accord??
Old Jun 11, 2008 | 05:54 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default ticking sound in motor accord 91 ex??
when i start the car and let it idle.for like 10sec.i hear this ticking sound on the motor?is not that loud?what do guys think it causein the sound?looks like is coming from the motor.and today i got bad news my friends 94 accord got stolen from the mechanic shop?damn i don't even feel like takin my car to the local shop...
Old Jun 11, 2008 | 06:04 PM
TheMuffinMan's Avatar
He knows where you live!
valve adjustment?
Do you keep up on maintenenc?
Would you like to give any info on the car
Old Jun 11, 2008 | 06:27 PM
Genetically Gay
Default Re: (TheMuffinMan)
had the car for 7months now.when i first got it.was'nt making the sound.it just started about 1month ago..yes i been keeping up with the maintance like oil change about 2months.valve adjustment?how to fixed it?do i need special tool?
Old Jun 11, 2008 | 06:30 PM
Haha you pay someone to do that
Maintenence = the suggested Honda stuff, less oil changing
Like timing belt, water pump, etc
And mileage? Any CEL's any other problems?
Old Jun 11, 2008 | 06:37 PM
Genetically Gay
has about 250k miles.don't know how long previous owner kept on maintence all i know was when i change new oil it was hella black color.no cel light.i think is still runnin the stock waterpump and timing belt..only problem is ticking a lil bit.
Old Jun 11, 2008 | 06:44 PM
Genetically Gay
Default Re: (KILLAB17VTEC)
another is oil looks like is leaking lil out off the vavle cover bolts.i might need to replace new vavlecover gasket soon.
Old Jun 11, 2008 | 06:49 PM
The_Caged_Bird's Avatar
Does it go away once the engine gets good and warmed up?
Old Jun 11, 2008 | 07:17 PM
Genetically Gay
Default Re: (The_Caged_Bird)
does'nt go away.happens constant while the engine start runnin.only stop when shut off.the car runs good though.
Old Jun 12, 2008 | 05:39 AM
It's either a loose valve or piston slap.
Then again, it could be worn out bearings in an accessory drive.
Loose valve can be easily remedied, piston slap is going to mean rebuild.
How much do you have tied up in this little car? If it were me, and I had less than $1000 in it, I'd just drive it until it finally died, but if I wanted to fix it, I'd go buy a junkyard motor, rebuild it, then switch 'em out one weekend.
You could "just get by" by going with a heavier weight oil, (10W-30 to 10W-40) and see if that helps it but you would just be prolonging the inevitable.
Old Jun 12, 2008 | 06:59 AM
SpazMan's Avatar
I found that putting 10w30 in at the last oil change has quieted my car (1992 Accord) considerably. I figure that after 168k, things would be worn enough to warrant a thicker oil.
Change that timing belt! It's an interference engine!
Ari
Old Jun 12, 2008 | 07:33 AM
91h22cb7lx's Avatar
Default Re: (SpazMan)
at 250k, its been changed atleast twice, I wouldnt push a non-oem belt a mile over 100k, some even say 60-80k in the instructions
SlowSOHC-T
10
Apr 6, 2014 03:17 PM
danny_379
Oct 11, 2012 02:32 PM
entityrob
Aug 12, 2011 02:50 PM
wfis5202
Feb 19, 2011 08:14 PM
sifka4
Jun 8, 2007 02:37 AM
